SSID Mismatch Gpu Flashing
40 (0.08/day)
Processor Amd Ryzen 5 3600
Motherboard Gigabyte B550m Aorus Elite
Cooling Id Cooling Se-903 XT
Memory 2x8GB T-Force Delta @ 3600MT/s
Video Card(s) Sapphire Nitro+ Rx 580 8gb
Storage 2x Lexar 128gb, 1x Seagate Barracuda 500gb Hdd
Display(s) Hp Z22n G2
Power Supply Thermaltake Toughpower GF 650W
Mouse HyperX Pulsefire Haste (wired)
Software Windows 11 Pro x64
Hello,
I am trying to flash my Sapphire Nitro+ Rx 580 8gb bios to the Original ones. The reason I'm flashing is because It has the Gaming bios of Msi. The gpu has dual bios and one of them is original from sapphire and the other is from msi. The previous owner might've flashed the msi's one in the Gaming mode bios. I want to revert it back to the Sapphire Gaming ones, because It's giving visual glitches. Whenever I try to flash It gives error "SSID mismatch" in the cmd. I already have tried force flashing but that doesn't work in the 3.31 . I'm using the Amdvbflash 3.31 to flash it because 2.93 isn't avaiblable for download. The bios I'm downloading is https://www.techpowerup.com/vgabios/191262/sapphire-rx580-8192-170320 Please can anyone help, how to bypass this error and get a successfull flash.
Cpu: intel i3-9100
Ram: 1x 8gb 2666mhz
Gpu: Sapphire Nitro+ Rx 580 8gb
Mobo: Gigabyte H310m D2vx si 2.0
Strange, I just downloaded version 2.93 from "TechPowerUp NL" mirror. Did you try a different mirror?
Hello
Below you have a picture showing how to find the link to 2.93
Hello
Hello, I downloaded the version 2.93 but when I try to flash It gives me a error "Due to Microsoft Enhanced features this Application requires the user to be in Administrator mode." Even though I ran the cmd with admin privileges. I am using windows 11
Version 2.93 was released when Windows 10 was mainstream. Do you have a computer with Windows 10 where you can put temporally the graphics card in it?
I would move ATIFlash folder out of C: root, Windows doesn't like 3rd party applications in there. If that doesn't help, try ticking the checkbox "Run as administrator" for amdvbflash.exe, also check: Run in compatibility mode with Windows 10, under the Compatibility tab (hoping Windows 11 still has these options).
I ticked both of the amdvbflashWin.exe and amdvbflash.exe "Run as administrator" and move the AtiFlash folder to different drive. The Os System Requirements dialogue box still appears but when I click ok the process works, should I still continue the flash? It's saying "ROM UNLOCKED" after I click ok in the dialogue box
Did you try running with Windows 10 compatibility mode for amdvbflash.exe? I can't guarantee that it's going to work in this situation, as I never used amdvbflash. I'm just helping out on executable requiring admin privileges.
There's no windows 10 option only till windows 8
Can you try "amdvbflash -f -p 0 rx580.rom" after executing "amdvbflash -unlockrom 0"
Thank you It worked. Successfull flash :)
Enjoy your card mate!
