- Aug 10, 2008
- 299 (0.05/day)
- Saigon city
System Name | Kurise PC |
Processor | i7 5820k 4,7ghz / Ryzen 1700x 4ghz / 8700k |
Motherboard | Asus X99 deluxe / MSI x370 gaming pro carbon / z370i strix |
Cooling | EK evo, xspc slim 360 rad, D5 pump, dual alpha cool GPU mono block, dual xspc 240 radiator, DDC 18w |
Memory | Crucial sport white 16gb x 8 128gb 2666mhz/ Crucial sport white 16gb x 4 64gb 2933 / ddr4 chinese 32 |
Video Card(s) | GTX 1080Ti SLI / HP gtx 1080 SLI 1850/1520 / 2080ti ref |
Storage | Lite on 512GB x 3 / Plextor m2 256gb / samsung 970 evo |
Display(s) | AOC I2769Vm, AOC U3477PQU, AOC I2769Vm / Koios 40''/ eizo EV2730QFX 1:1 |
Case | Xigmatek Elysium / Corsair 750D / Bitfenix prodigy M |
Audio Device(s) | creative blaster ZX / Blaster ZXR / Blaster x7 lmt + burson v5i upgraded |
Power Supply | Be Quiet 1200 / Thermaltake toughpower 1200w / chinese 750w sfx PSU |
Mouse | Asus Echelon/ steelseries black ops II/ james donkey |
Keyboard | Cm storm quickfire pro / Fire rose steampunk kb/ corsair k70 |
Software | Windows 10 |
I have two questions since i have an Alphacool eisbaer solo and a 360mm radiator, i use soft tube with i/d 9.5mm i intend to use smaller i/d tube like 6 or 8mm will it give me better results ?, the default pump of mine is 72l/h which i think is too weak, i intend to use 2 more 72l/h alphacool to the loop. I just want to have an easy install and remove set up since i always change my main rigs so i switch to soft tube instead of hard acrylic tube. AIO is not an option for me since i prefer 360/420/480 copper radiator then most AIO aluminum radiator. Should purchase silverstone tundra AIO which i believe the pump is 200-250l/h or to enermax 400-500 l/h and change the aluminum radiator to copper ?!
i'm using 1700x 4.0 1.45volt cinebench temp is 70*c with a slim magicool radiator ambient temperature is around 29-30*c , i will purchase 9900k which i believe is hotter and expect to fulload around 80-90*c with intel burn test or prime95 .
