- Nov 8, 2020
- 474 (0.28/day)
System Name | Dusty |
Processor | 5900x |
Motherboard | MSI B550 Tomahawk |
Cooling | Noctua NH-D15 |
Memory | Corsair Vengence LPX 32GB |
Video Card(s) | MSI RTX 3070 Gaming X |
Storage | yes |
Case | Fractal Design Define R6 |
Power Supply | EVGA SuperNOVA 750w |
VR HMD | Oculus CV1 |
Aloha!
I got myself a question regarding the issue of static noise that I been having for a few months. It used to work perfectly attaching my audio stuff to the back of the motherboard. Then one day people on discord said they cant hear what I say, all they get is static.
Plopped things in to the front panel and its all good.
The issue now is, I also use the line in to get audio from my consoles in to my PC, so I can play on my PS4/switch while for example, on discord with some friends and have both audio sources in my headset. So far so good, except, the massive static I get from the back which of course is annoying on the line in (or microphone if plugged in back as well).
Now as I said, it used to work just fine since I finished this setup around the time of when the 8700k was released. It was not until ~6 months ago I got this problem, cannot remember making any changes.
However, what I have noticed is, if I grab the power cord at the back of my powersupply, and I push it inwards and hold it there, the amount of noise drops dramatically. And when I let go (or at least, stop pushing it) it comes back.
Here is a little example of what it sounds like, at 9 seconds I start pushing the plug harder against the power supply socket, and I later let go and as you can hear, the noise increases again.
Produce_0.m4a - Google Drive
Now my question is of course, what can I do? And why? Why would it be more noise or less noise just by forcing the power plug against the power supply socket harder? I tried with several different cables, also tried different wall sockets, with and without a power strip etc. without any change.
Of course getting another device for the audio, a sound card or a external one would most likely work but in this case I am curious as to why the amount of static I get depends on how hard I force the power cable in to the power supply, I find that quite strange.
