strange voltage readings with speedfan
2,817 (0.42/day)
louisiana
Processor Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W
Motherboard GIGABYTE B760M--DS3H LGA 1700 DDR4
Cooling CPU - Thermalright Assassin King 120 SE / Case - cooler master 120mm rear case fan (Air cooling)
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600)
Video Card(s) GTX1060 6GB
Storage Samsung 1 TB 870 EVO SSD Main Drive / Samsung 500 GB 870 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Power Supply CORSAIR RM-750X 750W Modular ATX
Software Windows 11 Pro 64bit Edition
i just downloaded speedfan 4.33 and im getting strange voltage readings. (-12v is 16.97 ??? and the +12v is 2.94 ???)
the system is in my specs and i'm not sure if i need a patch or something but i'm guessing its not fully compatable with my board. the temps look ok but voltages look weird, should i just ignore it and write it off as the voltages are just not able to be read correctly?
here are the readings im getting:
followup readings with voltmeter:
+12v - 12.16v read this same reading from 4 pin molex, all 3 pins on 6 pin video card power, and on the 4 pin cpu power plug
+5v - 5.12v on the 4 pin molex plug
i couldnt get to the main plug on board very easy so i didnt get readings from it but im not seeing anything out of the ordinary so far, do you think i need to start moving stuff around to check the main plug?
ignore it..
trog
reg with speedfan and get the latest beta, it fixed alot of my issues with it.
i thought v4.33 was the latest version?
reg? why should i register? or do i need to in order to get the updated beta?
Speedfan and Everest always spew out wrong numbers for me also. :( Reported 9.7 on my +12v.:eek:
so what did you use instead of them? i might need to switch too.
