System Name | Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022) |
Processor | R7 5800X @ Stock | i7 12700H @ Stock |
Motherboard | Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231 |
Cooling | Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling |
Memory | TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16) |
Video Card(s) | Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W |
Storage | 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD |
Display(s) | Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in |
Case | Corsair 600C - Stock Fans on Low | Stock Metal/Plastic |
Audio Device(s) | Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29) |
Power Supply | EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light) |
Mouse | Logitech G502 | Logitech M330 |
Keyboard | HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW) |
Software | Windows 11 Pro x64 | Windows 11 Home x64 |
That is because they will, the ID for your 9550 won't match the ID for a 9600. If you are confident that the bios will work for your card you need to use the -f in the command line to force the flash (I believe it's -f). Be warned if you force flash an incorrect Bios you may ruin your card or have to Blind Flash (flash without monitor display) back to your original Bios. Also make sure you have a good backup of your original 9550 Bios just in case. Hope that helps!![]()
I would start with reading this article which was found under the Articles section at this sites main page:
http://www.techpowerup.com/articles/overclocking/vidcard/107
It's an article about modding a 9550 to a 9600. That should help you with your situation and give you the confidence to do it. Just be aware of the concequences.![]()
Also, you should fill your system specs by going into User CP.![]()
Hey, why don't you just get the Softmodded drivers to OC your 9550 ot 9600+ speeds? I mean, the flashed Bios is more for just speed and identifacation. You're not unlocking anything, just increasing core/mem speeds, but if you get the Softmod patch for ATI drivers, or ATI Drivers w/Soft Mod patch, then you're good to go! I know Omega's ATI drivers have all come with the soft mod patch.![]()
