switching between GPU's need help!
Darkgundam111
626 (0.11/day)
Processor QuadCore AMD Phenom II X4 Black Edition 940, 3500 MHz
Motherboard Biostar TA790GX XE
Cooling fans and hs
Memory CORSAIR XMS2 DHX 4GB (2 x 2GB) 800mhz 4-4-4-12
Video Card(s) Galaxy GTX 460 [retired -> XFX 8600 GTS (931/1917/2300)
Storage OCZ Vertex LE
Display(s) Acer G235H
Case Antec Nine Hundred Black Steel ATX Mid Tower
Audio Device(s) motherboard built in
Power Supply CORSAIR CMPSU-550VX 550W
Software windows 7 ultimate 64
So i installed a fresh copy of windows 7 onto my alienware m11x r1 which does not use the optimus drivers for switching video cards. Before it was reformatted, it had this nividia icon on the tray that allowed me to switch GPU's on the fly. Now tho, I do not see it and cannot find any drivers/applications to install that would do this again. I checked dell's website for all the drivers but none of them did that. Also checked alienware, but they don't have this model since they moved their support to dell. Lastly, i checked nvdia but no luck there either. any ideas how to get that back? i really dont want to have to restart each time to change GPU in the bios :(
um i just stated that this is the r1 version of the m11x...which means that it does not use the optimus drivers.
Switch on the fly? Like while they are in use? Why would you ever need to do that?
it was this nvidia application that allows you to switch from intel graphics to the 335m card in windows. on the m11x laptop, it allows you to shut off either the nvidia card or the intel card, which would allow you to either save battery or have higher performance depending on what I am currently doing.
edit: i have figured it out. just had to incorporate the new drivers into the old nvidia install package
Glad you got it working. It's a great thing for Both Nvidia and ATI to set up this way to swap video card use.. My HP Touchsmart has the AMD version.
I guess its helpful for laptop or something. My desktop GPU will drop to idle mode which only uses 16 W of power when I am not doing anything GPU intensive like gaming or Folding. All GPU's have done this for the last 5 or 6 generations and this switching is completely pointless for a desktop.
