System does not boot - post code 53
119 (0.03/day)
Hello everyone,
I've assembled my new PC today, but unfortunately it fails to boot :(
Asus ROG Strix X99 Gaming
What is working:
· All of the fans
· HDDs
What is not working:
· Nothing on screen
· Stuck at post code 53
· Chassis power button
I am pretty sure I plugged everything correctly.
How do I debug this?
What I tried so far:
· Booting without the GPU installed
· Booting with just 1 stick of RAM, in different slots
- The XMP switch on board
Thank you,
Kfir
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Set your Ram manually, that is a memory error. Try with one stick of Ram if you have to to get started. Maybe it just needs reseating.
119 (0.03/day)
Hey there! Thank you for attempting to assist.
What exactly do you mean by that?
I did try to post with just 1 stick of RAM, but same issue.
6,270 (0.89/day)
New York
List all your hardware and we will attempt to figure it out from there. CPU and RAM and Video card ext.
119 (0.03/day)
Sure thing :)
CPU: Intel Xeon E5-2699 v4
Motherboard: Asus ROG STRIX X99 GAMING
Graphics Card: Gigabyte GTX1070 Xtreme
RAM: 2x8GB G.Skill TridentZ RGB (2,400 Mhz)
Power Supply: SeaSonic X-660W
19,379 (3.46/day)
Update bios to the latest...
Is there a MEM OK button on that board? Use it.. :)
If not, set xmp in the bios, and before saving, manually set System Agent (SA) and VccIO voltage .1 over what its reading in the bios.
Not sure where that is... get familiar with your bios. :)
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
your mainboard could have a older bios then what it needs for 2699v4 which is bios 1701.
you can flash with:
http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/
there is a sticker in between cpu and your right ram slots and the last 4 digits is your current bios version
119 (0.03/day)
Well then.. Turns out it really was the RAM.
Apparently there is a "working configuration" setup, that will only boot if placed in the specific places. Who knew.. First time dealing with X99, guess RTFM really is important ;)
For those who are interested, the RAM configuration of ASUS ROG STRIX X99 should be as follows:
Thank you to everyone who assisted, it was really helpful!
Best of luck,
Kfir
you can flash with:
Thank you both for attempting to assist! :)
