System Hang/bluescreen at giveio.sys
Levi28001
30 (0.01/day)
System Name Triple Power
Processor AMD Phenom II x3 710 2.6ghz 'oc 3.2ghz
Motherboard XFX AM2+/AM2 NVIDIA nForce 750a SLI HDMI ATX AMD Motherboard
Cooling CPU Artic Cooling Freezer 64 Pro,1x140mm,1x120,2x80,1x60
Memory 2 gb 800/2gb 533 'oc 4gb 650mhz
Video Card(s) xfx gtx 260 core 216 'oc 695/1500/1101
Storage Samsung Hd300
Display(s) Hp w19
Case Antec 300
Power Supply Earth Watts 500w
Software Windows XP/Vista
Ok so my computer is blue screening at windows loading screen, with normal start and last known gd config. On safe mode start it hangs at giveio.sys, then blue screens. I know this problem can come with speedfan etc 3rd party stuff.
Is there any way to disable it/delete it?
I have windows xp sp3. Can't use recovery console since bro has windows cd at his house a ways away. Can't hook up hard drive to another computer because none of them have sata(well 1 does but its been stripped of parts).
Any ideas?
Edit:this thread may have been general software not really sure, sorry.
Try this.
Start Safe mode command prompt. Navigate to the directory where the offending driver is and rename it. Reboot and see if any other ones are giving you problems and do the same to them.
Or, If you can't even get to the safe mode...
Make a boot cd or USB stick with file tools, dos and stuff. Boot to that and rename the offenders that way.
Ultimate Boot CD:http://www.ultimatebootcd.com/
Any good with DOS? Make a DOS USB stick or CD. Same process basically. Boot to it and rename the files.
FreeDOS here:http://www.freedos.org/freedos/files/
You can use a GUI interface w/ mouse and all:http://www.freedos.org/cgi-bin/lsm.cgi?mode=lsm&lsm=gui/opengem.lsm
Or, Use something like linux to boot and fix things.http://www.ubuntu.com/
Goodluck...:)
