System lockups?
4,520 (0.69/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
Its been awhile so what normally causes a system to lockup from memory its mostly CPU stability or RAM? this is a X299 system with a i7 7800x.
Tried
1. PSU replaced
2. SSD replaced
3. GPU replaced
Testing
1. Ram with no XMP
Stability issues can be from anything. Since you replaced half the computer already, it could be your ram...
Easiest way to find out is to run memtest and see if you get errors. Thats a start at least.
Could also be the motherboard thats coming to the end of its life. I had an X79 system that started to do the same.
I bet on ram too that was the first or second thing to replace, if ram pass, just try to disconnect all things (even a bad fan or hub conected to mobo can mess)
RAM and just an FYI no XMP probably isnt enough to test. You should properly test it.
RAM was replaced from the looks of it its the IMC.
Tried
1. PSU replaced
2. SSD replaced
3. GPU replaced
Testing
1. Ram with no XMP
Run the cpu stock with correct vcore and clocks, with correct volts to chipset, then enable xmp with correct vdimm, check your cooling temperatures, also system event viewer/bluescreen view
Id test the cpu in another mobo if possible
