System unstable with high NB clock
hat
Enthusiast
21,755 (3.22/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I've discovered that my memory performs quite a bit better when I run my NB at 2500MHz compared to 2000MHz. In the AIDA64 memory benchmark, there's an improvement across the board in all areas, and not just in my memory, in my L1, L2 and L3 caches too. The problem is the system goes unstable when the NB is set to 2500MHz. What should I change? I can change CPU voltage, memory voltage, NB voltage and CPU NB voltage. For now, I've dropped the HT link speed down to 2000MHz while keeping the NB clock at 2500MHz to see if maybe the HT link went unstable. Specs to the left.
CPU/NB voltage is the "northbridge" voltage as it is listed in CPU-Z. It's really the memory controller. Keep HTT at 2000mhz, there's no reason to go higher and it makes no difference.
  • Like
Reactions: hat
Here's some before and after images. I'm not raising the HT link, just the NB frequency. I take it the voltage I need is CPU NB VID control?
You betcha. Do you know what the voltage is reading in the bios?
  • Like
Reactions: hat
Stock is 1.15v. That failed within 10 minutes. I tried 1.175v, crapped out around 45 minutes. Now at 1.2v...
Tested one hour stable at 1.2v, going to run it through the 8 hour test later tonight while I sleep.
You are not raising the right one? , you need to raise the CPU NB Vid control & not the NB voltage
The CPU NB VID Control should be at 1.2v stock & for 2500+ NB stable you will need about 1.350-1.375v
Mine is running at 1.4250v for 2660 NB
Also as Erocker said keep the HTT at +- 2000 , i keep mine at auto & stock voltage
  • Like
Reactions: hat
^ Yes, that is the voltage he is adjusting.
  • Like
Reactions: hat
Mine is 1.15v stock and passed occt for 1 hour stable at 1.2v. Maybe you need a higher voltage because you have a quad? I'm not sure if it's totally stable yet, will do a longer test overnight.
Your CPU NB VID voltage is too high, or you have a poor performing chip.
To OP, no more than 1.25v should be enough for 2500 mhz NB to be stable; somewhere between 1.21 and 1.25 should be enough, depending on how many sticks of RAM you're using and how much (if at all) you're overclocking the RAM.
  • Like
Reactions: hat
