Tech Bench Suggestions
Just some FYI, if you plan to use the T60 with a taller air cooler the handle may cause you some clearance issues. Other than that I really liked the design.
(specs aren't listed so I am just covering all the angles for you) ;)
Plan is to go water, but thanks for the warning. :)
the T60 is not made for water. no doubt that you can tweak it to accommodate a water cooling setup but i'd rather advise against it.
the tecnofront, although more expensive, is much better suited for this.
i really would rather recommend to go with the torture rack. it cost even more but you won't be disappointed
