Temp error with X850xt
SIK_L_CELL
13 (0.00/day)
Anytime I set the core over 640 I lose the temp monitor. It goes to 0 degrees. Anyone?
Hi Sik ... :) running the latest version correct?
I have the same problem, first I thought it was related to temperature rise while running 3d apps now I see that everytime I overclock the X850XTPE I lose the temp settings. If I load the stock profile the temp readings come back at the next check interaval. Then I load an overclocked profile and the temp is gone again. Very repeatable! :) :( I am on B2 and just noticed B3 is available, will try it there.
Added: B3 has the same problem reporting temps when overclocked.
same temp monitor proplem for me too x850xt
you must have an AWESOME core....watercooling ? I cannot even dream of getting mine at 640....
I am able to get to 630/626 before there are any artifacts, and the idle temp is 42 GPU and 49 ENV.
