[PausedUntilFurtherNotice] Converting Any Realtek Ethernet to Intel Killer Ethernet chip
425 (0.18/day)
System Name Asus TUF Gaming FA506IU Laptop
Processor AMD Ryzen 7 4800H with Radeon Graphics
Motherboard AMD K17.6 FCH, AMD K17.6 IMC
Cooling Dual Fans Design with Self-Cleaning Cooling
Memory Samsung DRR4 - 3200Mhz 16GB(8GBx2)
Video Card(s) GeForce GTX 1660 Ti (6 GB)
Storage WDC PC SN530 SDBPNPZ-256G-1002 + SHGP31-500GM-2 + ST1000LM035-1RK172
Display(s) LM156LF-2F03 144HZ Adaptive SYNC
Audio Device(s) Realtek ALC256 @ AMD K17.6
Power Supply ASUS Power Brick 180W
Mouse ROG SICA Gaming Mouse
Benchmark Scores CineBench R23 Single core:- 1290 points CineBench R23 Multi core:- 11111 points
I have realized that some Intel Killer Ethernet models are using Realtek chip and hence they use Realtek .sys files & drivers. So most laptops/PCs have Realtek ethernet.
Those models who are using Realtek chip are:-
  • Intel Killer Ethernet E2500
  • Intel Killer Ethernet E2600
  • Intel Killer Ethernet E3000
  • Intel Killer Ethernet E5000
They literally share the exact same .sys files between Killer ethernet chip vs non-Killer ethernet chip! So an idea came to my mind... why not convert non-killer Realtek chip to a Intel's Realtek Killer ones :D
The Killer app can take advantage of it if you are kind a guy who connects Wi-Fi and Ethernet cable at the same time... Killer app will allow to manage both & route background data like (Windows updates, downloads, Youtube/Twitch streaming, etc...) to your Wi-Fi/Mobile Hotspot while your ethernet will be used for ping sensitive things like online gaming, etc... or vise versa :)
This feature are named the same as on Wi-Fi... Intel® Killer™ DoubleShot™ Pro. https://www.intel.com/content/www/us/en/products/details/wireless/killer-series.html#tab-blade-1-3
Those images explains it more clearer ;)
Those are the settings that displays when I check device manager "Advanced" tab...
All what I am asking is... if you are interested and want to take advantage of this feature... maybe and I repeat maybe will provide improvements over stock Realtek driver? I don't know... hence testers are needed. :) Once we established that the Intel Killer (aka Realtek) driver is 100% stable and working. I will start and begin the process of making it to work with Intel Killer Intelligence Center App like I did with Intel Killer Wi-Fi Modded Driver
As long as you got Realtek ethernet no matter which model, it should work :) This is how it looks like in the future if it became successful inside Intel Killer Intelligence Center App :)
  • If you are willing to continue then please be careful and mindful on each step... I'm not responsible for any damages that result from the use of drivers that I will be providing to you. The driver is in Alpha/Beta phase and hence I am only providing it to cover & support as much models as possible. USE AT YOUR OWN RISK.
What I want from you is sharing your Hardware ID of your Realtek ethernet through device manager... here's a picture as an example:-
And I will provide you the driver to test it :) I was contemplating & in dilemma if it is worth my time but I said... let's see what happens :D if it became successful... I will starting working to make it available for Intel Killer Intelligence Center App and let Intel Killer Intelligence Center App to take advantage of your ethernet along with your Wi-Fi ;)
Notice:- Only works with Windows 11
Time unlocked.
Hello.Mr.THEBOSS619:rockout:
I'm excited about this project:peace:peace:
Oh, it didn't work in my environmento_O
This is my Realtek PCIe GbE Family Controller.
PCI\VEN_10EC&DEV_8168&SUBSYS_07061028&REV_10
PCI\VEN_10EC&DEV_8168&CC_020000
Please let me participate in this project:respect:respect:
I will try to unlock and unhide those options... :) will share it here once it is successful ;)
  • RSS Queues
  • Interrupt Moderation Level
  • IdleRestriction
Hey, thank you for your kind words :respect: , Here, this should work for you :)
  • RSS Queues
  • IdleRestriction
Oh, this driver doesn't work either o_O
Is there any way to fix it?
Would this driver work on an I225-V 2.5Gb controller?
Is it possible to convert this one too?
I'm curious and interested :D
Here :) Try it and report if it works or not ;)
Are you using Windows 10? Because it won't work on Windows 10, It only Windows 11.
If you are using Windows 11 then don't worry... I will try to find a way to fix it for you :)
why not, lets give it a try... ;) worst case scenario it will BSOD :D share your HWID and I will provide you with the driver :)
Changelog:-
Updated the .sys file to the latest release ;) and also unlocked & unhidden those options... :)
  • RSS Queues
  • IdleRestriction
Download from the attachment of this comment :)
Changelog:-
  • RSS Queues
  • IdleRestriction
View attachment 369612View attachment 369611
YES! It's working perfectly!
But only the wifi card is showing up in DoubleShot Pro.
Thank you THEBOSS619 :rockout:
The driver has an error message and says it doesn't worko_O
I'm using Windows 11_24H2
I'll attach the hardware ID again
If you need anything please let me know:respect:
Great to hear it is working for you! :) Will do it later and will make it work with DoubleShot Pro after making sure it is stable 100% :) I have also said that on the main post :)
Oh thanks for the images, I will try provide you another driver fix later ;) will let you know as soon as possible :)
I had just woken up and didn't even realize you had mentioned this in the main post xD
Oh no worries at all! thank you so much for your time testing the driver :) please let me know if you faced any issues with it and report it here ;)
It is still beta testing phase and I'm trying to find out bugs and fixing it :D the more people use it.. the more people reports it = the faster I fix bugs and make it stable = the sooner I start working to make DoubleShot pro see it and take advantage of it :)
[ Network adapters / Killer E2600 Gigabit Ethernet Controller ]
Device Properties:
Driver DescriptionKiller E2600 Gigabit Ethernet Controller
Driver Date7/29/2024
Driver Version1168.20.729.2024
Driver ProviderKiller
INF Fileoem258.inf
INF SectionRTL8118AS.ndi.NT
Hardware IDPCI\VEN_10EC&DEV_2600&SUBSYS_170F1025&REV_21
Location InformationPCI bus 109, device 0, function 0
PCI DeviceKiller E2600 Gigabit Ethernet Controller
Device Resources:
IRQ65536
Memory821FB000-821FBFFF
Memory821FC000-821FFFFF
Here are the hardware ID's on my laptop and Thunderbolt dock.
Realtek Gaming 2.5GbE Family Controller
PCI\VEN_10EC&DEV_8125&SUBSYS_15E11458&REV_05
PCI\VEN_10EC&DEV_8125&CC_020000
Realtek USB GbE Family Controller
USB\VID_0BDA&PID_8153&REV_3100
PCI\VEN_10EC&DEV_8125&SUBSYS_87D71043&REV_05
Device Properties:
INF Fileoem258.inf
Device Resources:
IRQ65536
Thank you for those HWIDs :respect: Will start working on it soon and I will get back to you all in a couple of hours :)
Edit:-
@Hotlod @ggsmida @ifly53e @ronildo66 Here, try this one, hopefully it works ;) download the file from the attachment :)
Edit:-
Oh no, it doesn't worko_O
It says there is no object:(
I understand how to install it from the previous killer:rockout:
Ok try this one :) This should work :)
Changelog:-
  • Add devcon tool to help installing wild card HWID
I've made some progress :peace:
I'm using Diver with Intel Killer Performance Suite version 36.24.843.
I installed this driver after the last one you uploaded and it worked perfectly.
Also, killerapp doesn't show any details but it does show two aKiller_Drivers.
I'm excited:clap:
Does this help anything?
A correction.
killerapp now shows the LAN details:rockout:
I'm sorry for the blacked out stuff:respect:
Edit:-
@Hotlod @ggsmida @ifly53e @ronildo66 Here, try this one, hopefully it works ;) download the file from the attachment:)
and Add devcon tool to help installing wild card HWID I've used both to check:)
Realtek PCIe GBE Family Controller
I tried, but it wouldn't accept it.
My hardware is old.
Anyway, I tested it just in case. It's not so important, as long as the wifi works.
I'm excited:clap:
A correction.
Edit:-
Still haven't started to work out & making sure that Intel Killer Software Suite works with LAN :) Let's make sure that it works for it 100% ;)
Nice way of going testing stuff :toast:
Did not work for this one...
Adding driver package: e5xw11x64.inf
Driver package added successfully.
Published Name: oem2.inf
Driver package installed on device: USB\VID_0BDA&PID_8153\001000001
Updating drivers for USB\PID_8153 from C:\Intel(R) Ultra Killer(R) Realtek Ethernet\Driver\e5xw11x64.inf.
devcon.exe failed.
Success on this one...
