The best cpu cooler
Volatile
43 (0.01/day)
Connecticut
Processor Intel Core i7 920
Motherboard Asus P6T
Cooling Stock
Memory 12GB OCZ Tri Gold
Video Card(s) Nvidia GTX 260
Storage WD 1.0 TB, Seagate 1.5 TB.
Display(s) AOC 19" Wide Screen
Case Airflow Extreme (Forget Brand DX)
Audio Device(s) HD Audio- Motherboard
Power Supply Ultra 650W PSU
Software Windows 7
Lately, I have been looking for a possible upgrade for my computer and after trying to determine what i could upgrade, I realized that i am still running stock fans for my Core i7. I haven't overclocked it yet because i was concerned about overheating. Simply put i would like to buy the best cooler for it possible, ive been doing research but most of the reviews ive found are 6+ months old and I am not sure if something knew has come out or whatnot.
If you see anything that you also reccomend i upgrade dont hesitate to let me know as well :)
Here are the system specs and the two that i have found so far:
CPU: Intel Core i7 920 @ 2.67ghz @ 45 degrees celsiuis right now
RAM: 12.0 GB OCZ Triple-Channel DDR3 @ 535Mhz
Motherboard: ASUS P6t
Gfx: 2688MB GeForce GTX 260 @ 56 degrees celsius right now
HDD: 1TB WD
And this is the case: NZXT Tempest ATX Mid-Tower Case
http://www.tigerdirect.com/applicat...CODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
1. Sunbeam Core Contact Freezer
http://www.newegg.com/Product/Produ...TC-Froogle-_-CPU+Cooling-_-Sunbeam-_-35207004
2.Thermalright Ultra-120 eXtreme CPU Cooler
http://www.xoxide.com/thermalright-ultra120-extreme.html
Thanks =D
9,899 (1.66/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
I'd say get a corsair H50, costs the same as the true and if you put two fans on push pull it beats a true with fans in push pull.
Only just but still : ]
No big heatsink to block airflow as well so you can cool the Mosfets and NB better.
[Ion]
WCG Team Assistant
13,391 (2.35/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
Prolimatech Megahalems
'Nuff said
Although the Corsair H50 (liquid cooling) is very good, as is some Noctua model (don't remember exactly), but it costs close to $90 :eek:
sneekypeet
not-so supermod
29,712 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
its a NH-D14 and the mega will run you close to the same once you add a fan or two, that isnt supplied with a $70 cooler;)
Volatile
43 (0.01/day)
Connecticut
Cooling Stock
Software Windows 7
The NH-D14 looks very nice, is it worth the price though? Or would I only see a minor performance boost?
vaiopup
840 (0.13/day)
England
System Name Crunching and smapping!
Processor i7 920@3.8
Motherboard Gigabyte EX58-UD3r
Cooling True
Memory 6gb Gskill pc12800
Video Card(s) Crossfired 5770's
Storage 1tb Samsung Spinpoint
Display(s) 50" Panny Viera 1080p
Case Antec 200 I think
Audio Device(s) Audio via Logitech 680's or 580's....or something
Power Supply Corsair 850 TX
Software Win 7 64
Benchmark Scores Just a few coffee stains!!!
From what I have read the IFX? beats the True and the 'halems.........but then with a tri fan setup it should.
sneekypeet
not-so supermod
29,712 (4.27/day)
System Name EVA-01
Aside from a TRU which I havent had the pleasure of testing myself, the Noctua is the best performer I have had my hands on. I will limit that a bit though. Let's say best I've used out of the box.
2,706 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
vaiopup
840 (0.13/day)
England
Cooling True
Software Win 7 64
9,899 (1.66/day)
Essex, England
System Name My pc
VS stock cooler you'd see a huge performance boost :laugh:
The NH-D14 is the best air cooler out at the moment.
I'd still go with the Hydro personally though, I really don't like big heat sinks now I have domino A.L.C, I'm getting the same temps as I did with me true ( 2 fans on true) and I'm only using one fan on this until my case if finished being modded : ]
By the by, the A.L.C can perform the same as a hydro, but you do have to mod the A.L.C for it to you know, work decently :laugh:
sneekypeet
not-so supermod
29,712 (4.27/day)
System Name EVA-01
In all honestly, if you are new to clocking and dont want to break the bank, that Sunbeam CCF is plenty enough cooler, and cheap too.
9,899 (1.66/day)
Essex, England
System Name My pc
Oh yeah, there is that too :laugh:
Would an OCZ Vendetta be enough to cool i7?
Because they're even cheaper and get rave reviews.
vaiopup
840 (0.13/day)
England
Cooling True
Software Win 7 64
Having all ram slots filled may limit clocking anyway.......I would just go for a decent midrange cooler and settle for 3 ghz or so.
Unless you are crunching you may not utilize the speed anyway.
9,899 (1.66/day)
Essex, England
System Name My pc
I've never had this problem with any mother board or ram set up.
Is it really that common a problem?
sneekypeet
not-so supermod
29,712 (4.27/day)
System Name EVA-01
OCZ Vendetta, Sunbeam CCT and Xig 1283 are all the same cooler.
Also dont assume for 12GB all slots are full there are 3X4GB kits of ram. Corrected in the following post.
Volatile
43 (0.01/day)
Connecticut
Cooling Stock
Software Windows 7
All slots are filled, 2g *6.
Money is not an issue here as well, I am just looking for something that I could overclock to around 4ghz and keep it stable. Why would having all slots filled be an issue?
vaiopup
840 (0.13/day)
England
Cooling True
Software Win 7 64
Not aware of any 3 x4 gb OCZ sets.
9,899 (1.66/day)
Essex, England
System Name My pc
All slots are filled, 2g *6, Money is not an issue here as well, I am just looking for something that I could overclock to around 4ghz and keep it stable, why would having all slots filled be an issue?
It seams ALOT of people get reduced over clocking head room when they have all slots filled.
I've never had the problem and can over clock my ram and CPU to silly amounts even with all slots filled :laugh:
Guess I'm lucky though.
4ghz you say?
Then you'll be wanting a pretty damn huge air cooler, IFX-14 or the Noctua for best results.
Or as said Corsair H50, when you get the H50 for best results remount the fan so it blows through the radiator and out of the case : ]
Volatile
43 (0.01/day)
Connecticut
Cooling Stock
Software Windows 7
I think i'm going to go with the NH-D14, will I have any problems fitting that in my case with the GTX260?
2,706 (0.41/day)
Oulu, Finland
Mouse Logitech G700
sneekypeet
not-so supermod
29,712 (4.27/day)
System Name EVA-01
As long as the spreaders arent tall it will work. Just makes swapping out the ram a PITA;)
9,899 (1.66/day)
Essex, England
System Name My pc
Ram would have to be low profile to right?
sneekypeet
not-so supermod
29,712 (4.27/day)
System Name EVA-01
thats what I meant about the spreaders. There is a fair bit of room between my ripjaws and the cooler, but ram like Pi's or reapers just wont cut it. His OCZ Golds should be fine under it.
9,899 (1.66/day)
Essex, England
System Name My pc
Ah I wasn't paying attention to what ram he had, yeah its pretty much standard height.
Your golden for the Noctua if that's what your going for! :D
Volatile
43 (0.01/day)
Connecticut
Cooling Stock
Software Windows 7
Yeah it looks good, thanks guys! One last question, where can I buy it? I don't see it on newegg...
