- Feb 14, 2024
- 44 (0.10/day)
So my PC has been rebooting randomly since I built it in early feburary. Haven't figured out what caused it after half a year of trial and error (event viewer shows Machine Check Exception; Cache Hierarchy Error). Haven't tried this. I'm sorry if if I dont fully explain everything. Basically, the WudfRd driver fails to load for my headset (HyperX CLoud 2), I've seen others with the same issue, and its been causing reboots for them aswell. When trying to fix it I get stuck though. I was trying to follow this guide, but the issue is Windows Driver Foundation doesn't exist in my services, then I tried to fix that, which led me to this guide. The issue with that is
that this pops up when pasting the commands into command prompt. I don't know what to do about this. The only asnwer I've found online seems to be copied from the website I got the command and guide for, so nothing actually about fixing this specific error that pops up, only things about specific porgrams lacking the file, but the file in itself seemingly doesnt exist, and its no specific program that brings up the error, its trying when trying to actually add windows driver foundation
Specs;
GPU: AMD Radeon 6650XT
CPU: AMD Ryzen 5 5600
Mobo: ASRock B450M Pro4 R2.0
Ram: 16GB Kingston Fury Beast DDR4-3200
SSD: 1TB Lexar NM620 M.2
PSU: 700 Watt be quiet! System Power 9
OS: Windows 10 Pro
Specs;
OS: Windows 10 Pro
