Thermal pads for VRM circuit (STRIX GTX 970)
  • Thread starter Thread starter Deleted member 6693
  • Start date Start date
Deleted member 6693
I have just changed the thermal compound on the GPU, as it was getting hotter.
The old compound was stiff and almost dry - put some GELID Extreme on, and is now fine with the temps again.
But - I also removed the VRM heat sink to check the pads, and in that process, I damaged the pads (they ripped apart on the removal of the heat sink)
Any suggestions on where to buy thermal pads? What is good quality?
Normally something like this is used, as it's easier to work with strips rather than little squares - https://www.amazon.com/Fujipoly-mod-smart-Extreme-Thermal/dp/B00ZSJRH22/
Or you could get something like this and cut it in strips, but it can be a bit messy to cut - https://www.amazon.com/ARCTIC-Thermal-Pad-145-0-5/dp/B00UYTTLI4/
If you want to go with branded stuff, then there's this, but it might be a bit on the thick side - https://www.amazon.com/Thermal-Grizzly-Minus-High-Performance/dp/B00ZJS8RWQ/
Some cheaper generic stuff, which will most likely be good enough and which is a lot cheaper - https://www.amazon.com/FBApayipa-400mm-Silicone-Thermal-Heatsink/dp/B01N9HGKR1/
Another cheap option - https://www.amazon.com/Teenitor-Silicone-Thermal-Heatsink-Printing/dp/B06XX7ZMN7/
All that stuff is generally much of a muchness imho, as something like the VRMs won't have perfect contact with the heatsinks anyhow.
if you have any old/broken sticks of RAM, they often use thermal pads inside them to create contact between the ram chips & the metal HS. open up a stick, and harvest the tape.
english please, all i understand is Grizzly part.
edit, nvrmind.
