Thermal pads not touching block?!
452 (0.15/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 4x8gb 3000mhz (temporarily running 2x 32gb ddr4 corsair vengeance 3600mhz)
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Razer Basilisk v3
Keyboard Logitech G910
Software Windows 10 64bit
For some reasons some of my thermal pads aren't touching the ek waterblock for the aorus xtreme edition 1080 ti
https://imgur.com/gallery/5eZgd
Sorry about image not being embedded. I know it's IMG with brackets but there's also a url bit needed I think which I have to get on my pc to find out
URL]
It looks like you have pads on things that don't need them.
Did you apply the pads like this?
possibly you have put 1mm pad or 0.5 where thinner stuff should go, raising the block toomuch for another thin bit, dya get that
did hat make sense
I don't believe so. On the instructions the row that has the hexagon shaped thingies I'm supposed to put 1mm pads on. I'm trying 0.5mm right now just in case. I'm not sure which ones are the vrm
After much research online though I have read on overclock.net in the aorus xtreme edition 1080 ti owners club thread that apparently gigabyte have two different pcbs for the same card. The newer version has raised vrm apparently...
That might explain why me and 3 other guys have run into the same issue on the same card with the same block.
Worst case scenario I won't put any pads on those and thermal paste on the other ones that aren't touching... The other ones are already on 1mm except the high one of course as per the instructions
Edit *** omg you're right. I checked on their website and their instructions are different than the instructions that came with the block holy crap lol
Lookie this:
Wrong instructions? https://imgur.com/gallery/ZRnMS
URL]
Take the block off, and take a picture of the PCB please. One of us will circle what you need the pads on.
NM, did it for you. Looks to me like the pads you have on one of those sections is too thick. Use the thinner pads.
I ended up not putting pads on the fourth row as indicated in the more recent instruction manual on eks website
I put some paste instead on there. I also put some paste where the pads were almost touching the block to give it the reach it needed. Now everything seems to touch
