System Name | Cumquat 2021 |
Processor | AMD RyZen R7 7800X3D |
Motherboard | Asus Strix X670E - E Gaming WIFI |
Cooling | Deep Cool LT720 + CM MasterGel Pro TP + Lian Li Uni Fan V2 |
Memory | 32GB GSkill Trident Z5 Neo 6000 |
Video Card(s) | PowerColor HellHound RX7800XT 2550cclk/2450mclk |
Storage | 1x Adata SX8200PRO NVMe 1TB gen3 x4 1X Samsung 980 Pro NVMe Gen 4 x4 1TB, 12TB of HDD Storage |
Display(s) | AOC 24G2 IPS 144Hz FreeSync Premium 1920x1080p |
Case | Lian Li O11D XL ROG edition |
Audio Device(s) | RX7800XT via HDMI + Pioneer VSX-531 amp Technics 100W 5.1 Speaker set |
Power Supply | EVGA 1000W G5 Gold |
Mouse | Logitech G502 Proteus Core Wired |
Keyboard | Logitech G915 Wireless |
Software | Windows 11 X64 PRO (build 24H2) |
Benchmark Scores | it sucks even more less now ;) |
Do I soak the CPU or just dip the brush and gently remove it?ISO-propyl alcohol and a soft bristle brush is what I use
Processor | Ryzen 2600 |
Motherboard | X470 Tachi Ultimate |
Cooling | AM3+ Wraith CPU cooler |
Memory | C.R.S. |
Video Card(s) | GTX 970 |
Software | Linux Peppermint 10 |
Benchmark Scores | Never high enough |
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
System Name | Starlifter :: Dragonfly |
Processor | i7 2600k 4.4GHz :: i5 10400 |
Motherboard | ASUS P8P67 Pro :: ASUS Prime H570-Plus |
Cooling | Cryorig M9 :: Stock |
Memory | 4x4GB DDR3 2133 :: 2x8GB DDR4 2400 |
Video Card(s) | PNY GTX1070 :: Integrated UHD 630 |
Storage | Crucial MX500 1TB, 2x1TB Seagate RAID 0 :: Mushkin Enhanced 60GB SSD, 3x4TB Seagate HDD RAID5 |
Display(s) | Onn 165hz 1080p :: Acer 1080p |
Case | Antec SOHO 1030B :: Old White Full Tower |
Audio Device(s) | Creative X-Fi Titanium Fatal1ty Pro - Bose Companion 2 Series III :: None |
Power Supply | FSP Hydro GE 550w :: EVGA Supernova 550 |
Software | Windows 10 Pro - Plex Server on Dragonfly |
Benchmark Scores | >9000 |
I second the use of some quality electrical contact cleaner. Cleaning contacts is what it is made for. And as Bones noted, the spray avoids the need to scrub - like power washing your car in a touchless car wash. Some staining of PCB itself may remain. That's okay as long as the pins are clean.
Note if TIM (thermal interface material) got on the CPU, it could be in the socket too. Again, the best tool is electrical contact cleaner. CRC QD cleaner is a long time favorite of many techs. WD-40 makes a good contact cleaner too. Either is usually easy to find at your local home improvement store, or even Walmart.
Curious? Why did you remove the CPU to change the cooler? You normally don't need to.
And I note it is not normal for TIM to get on the pins/pads or socket unless WAY too much TIM was applied during cooler mounting and it squished out over the sides when mounting pressure was applied. A tiny bit of TIM goes a long ways. In fact, too much TIM is counter-productive to heat transfer efficiency. You want as thin as possible while still providing thorough coverage. Remember, the purpose of the TIM is to fill only the microscopic pits and valleys in the mating surfaces to push out any insulating air.
Mate you’re a legend. I am new to the pc world so I can’t really tell you why I pulled the cpu out instead of just cleaning it while mounted. I’ll be purchasing the wd40 specialist spray and use that to clean up the cpu. I couldn’t see anything in the socket looks clean to me. I really do appreciate the in debt info.I second the use of some quality electrical contact cleaner. Cleaning contacts is what it is made for. And as Bones noted, the spray avoids the need to scrub - like power washing your car in a touchless car wash. Some staining of PCB itself may remain. That's okay as long as the pins are clean.
Many thanks. I am giving WD40 a go. Fingers crossed. Thank you for the replyYou can also use electrical contact cleaner in a spray can that will simply remove it without having to brush it if you want - Just aim and blast away.
Do not use something like brake cleaner, that isn't good for it.
Acetone is another alternative in most cases.
Make sure though, whatever method you use to be sure the CPU is fully dry before reinserting into the socket.
Memory | C.R.S. |
