thermal paste on the cpu socket
664 (0.12/day)
System Name mine
Processor I7- 7700K
Motherboard MSI Z270 Mortor
Cooling Cooler master V6GT
Memory 16gb corsair
Video Card(s) Zotac GTX1080 amp!
Storage m.2 ssd
Display(s) Benq xl2411
Case SilverStone FT02 - ltd edition red
Power Supply Corsair HX1000
Software Windows 10 64bit
got a lil thermal paste in the cpu socket, ive cleaned it off and now thers just a shade on gry on ther, would this effect it at all?
Thermal paste on the lid? no, no problem.
Just make sure your paste is evenly distributed when you put your heatsink back on.
What thermal paste is it?
no, thermal paste on the pins, it came like it when i recieved it from kyle2020
id clean it more and then try it.
im on it now actually, it SEEMS to be runnin good with the CPU @ 3.3ghz
if its good, then its good..
but be careful for electrically conductive thermal paste such as AS5
it can short your pins and kill your CPU and Mobo..
if you connect 2 pins together on the socket, you can use cotton swap with alcohol to clean the socket and then dry it.
will have to wait till kyle chimes in to see wat thermal paste is is
Durrr, I'm an idot sorry. If theres thermal paste in the socket then you should clean it very carefully prior to using it.
+1000000 for cleaning thoroughly before using, best to use rubbing alcohol that is like 99% pure as it contain's less water ;)
