Thermaltake Tower 100 custom build, dual radiator mod
13 (0.00/day)
Specs:
Specs:Ryzen 5800X3dRtx 3090Asus rog x570 gaming I32gb ddr4 3800mhz CL14Thermaltake Tower 100Silverstone 1500W2TB Samsung 990 proCustom Watercooling loop.
Mods:
removed the glass and designed a custom grill in 2.5mm carbon fiber. I also shave the bottom tray to fit fans. I used slim fans (15mm)
Tiny space but great results, I was able to fit 2 radiators one 240mm on the side and one 120 on top. I modified the side panel, removed the glass and designed a custom grill in 2.5mm carbon fiber (previously designed in cad). I also shave the bottom tray to fit fans. I used slim fans (15mm)
It may seem that 24 hours of work modifying your pc seems little. But surely thinking about what elements you were going to put, and how you were going to do it took you a little more time. Also you do it with hard tube. I always thought that this case could admit a rad of 120 and one of 240, you have shown it. And also with class and simplicity. I would love to see a photo with all the lids and crystals in place. You have my 9 champion.
Thanks for uploading the mod.
Thanks for your words, yes, lots of thinking before even buying anything. then the cutting and making. the side panel carbon fiber grill for the rad i have few more in case someone want them. I can sell
