This is a payed Mac program to build a bootable cf card (and a live system) I havnt tried yet.
186 (0.03/day)
System Name Gaming PC from bestby
Processor I7
Motherboard Ibuypower
Cooling Stock
Video Card(s) Nvidia 3080
Storage 1TB shared with windows 11 and FerenOS
Display(s) MPG ARTYMIS 323CQR
Case nice big case with rainbow fans allover it
Audio Device(s) realtech
Software OS is Windows 7 home premium, sometimes I use linux mint mate or sabayon both live
Benchmark Scores CL-RCD-RP-RAS Write Speed 2x DDR3-1333 SDRAM 9-9-9-23 CR1 10484 MB/s
Disk Drill, I did install MacOS Big Sur that im on now. My Macbook Pro started with High Sierra but it was a lemon so I payed to get the partitioning sceme fixed and they installed Monterey.
I probably saved $100 installing Big Sur myself, The Pro version uses dmg files.
I had to use the chrome store custom toolbars because that thin, disappearing scrollbar isn't fun. I found out that the volume is inside the tubes icon in Big Sur and the screenshot app is inside the other section. In Monterey the screenshot is inside the toolbar.
I don’t really understand your post but you can make bootable media with disk utility
I dont think disk utility can make it live.
I haven’t tried since 10.12 or so but you could back then, maybe that’s changed though?
