Thoughts on the recent Igor's Lab thermal paste application article?
13 (0.01/day)
Igor's Lab has a new article on thermal paste application specifically for large GPU dies: https://www.igorslab.de/en/blob-or-full-flat-heat-conducting-paste-on-the-gpu-correctly-applied/
This has re-piqued my interest in this beaten to death topic which I thought was mostly settled. The advice I see most often today is use a ton of paste and let the excess squeeze out the sides, it won't hurt performance and at worst it just makes a mess. Igor specifically refutes this claim with his testing.
He also endorses the new alphacool apex paste, which he praises for it's higher viscosity that he claims helps with coverage and longevity in this application. He claims that thinner pastes, such as MX-4 (which I have personally been using mostly because it claims 8 years of endurance and that is very important to me) has no place on large direct die applications because in his own words: "You don’t have this problem with thin paste, but then the paste quickly runs out of the large gaps. Or it dries out and the layer becomes thinner and thinner after thermal heating and eventually cracks at the sides." He also goes on to recommend a specific mounting technique, deviating from the diagonal method I've seen employed most of the time.
I suppose I have a couple questions for the community:
Does everyone agree with his results? The majority of complaints I've seen in response come down to his sloppy application of paste while using the "spread" method. The other concern with the "sausage" method is the possibility of not achieving full coverage, which can be very bad without a heat spreader.
Do these complaints hold any water? Alphacool makes no claims about the longevity of their new apex paste, which has me a bit hesitant to try it on an upcoming hardline build where re-pasting will be a real pain. Does anyone know of any other proven, "thicker" paste options with reasonable performance and long term durability?
ir_cow
5,013 (0.82/day)
USA
Just a reminder for everyone this is for GPUs only.
I think Igor does great work and trusted source. The big take away here in the thermal paste type. He made it clear that "thin" and "thick" have different properties. In the end I will still cover the whole die and smooth it out with a plastic knife. It smooths it out so no paste area is larger and makes sure the whole die has contact. Check the temps to make sure its within tolerance and that's it.
Igor said the block pressure can only "push" so much thermal paste to the sides, that is why a blob in the middle, X, or even full coverage doesn't (may not) work well. This comes down the type of paste and the amount you put down.
To recap, if you use the same paste and video card, put a line down the middle. Otherwise all bets are off. This is the problem with all these tests. So many people have done it and get different answers. Not only is does the size of the area matter, but the type of paste and pressure that will be applied.
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
Doubt the blab application was large enough
But I large X and blab the center a bit more never with arctic paste though but with nt-h1 it's my fav.
2,668 (0.80/day)
I'm planning to just get a good quality thermal pad myself for next build. Paste is a pain and how to spread has many explains. I just feel pads have have gotten close enough and avoid the pitfalls of re-apply and try again after that comes with paste dry out.
5,471 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
Fascinating that the full surface application has the worse temperatures and by a lot at that; I will, however, continue to use this method as I want to be sure nothing is left dry.
I am very skeptical, but more than willing to be shown wrong.
329 (0.07/day)
Processor Intel i7-12700K
Motherboard MSI PRO Z690-A WIFI
Cooling Noctua NH-D15S
Memory Corsair Vengeance 4x16 GB (64GB) DDR4-3600 C18
Video Card(s) MSI GeForce RTX 3090 GAMING X TRIO 24G
Storage Samsung 980 Pro 1TB, SK hynix Platinum P41 2TB
Case Fractal Define C
Mouse Logitech G203
Software openSUSE Tumbleweed
I had a look at the photos by Igor's lab. The "full surface" (spread) method used too little paste. The blob also seems small. He should try again with "too much" paste, I think surprising results will arise.
As far as I've tested so far with my RX480, the more paste, the better the chances that full die coverage will be achieved. There's no real way to use "too much" paste unless it's very viscous and the cooler mounting pressure can't squeeze off the excess.
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
Not really after looking at the spread again it looks better for laying tile than gpu or cpu application so yeah worst spread I've ever seen frankly :laugh:
Damn use a credit card or something flat not a title trowel :eek:
64K
6,773 (1.67/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Looks like a good way to end up with small air pockets. I wouldn't apply this way. I don't care what the expert says.
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
I have had good results with the spread method
But both surfaces should be thin and smooth not rough and random ruts indeed air trap city.
13 (0.01/day)
I see this statement often online, the belief of air getting trapped if the thermal paste isn't applied smoothly enough. I don't know enough about this subject one way or another to have a solid opinion. I'm curious what people think of the information and photo in this post: https://www.overclock.net/threads/3090-gpu-hotspot-temperature-30c-delta.1777947/post-28953759
What's being presented there is that if the mount between the heatsink/waterblock is optimal almost all of the thermal paste will be forced out between the mating surfaces leaving only an extremely thin film of thermal paste. This makes a lot of sense. It's recommended that applying more is better than less to achieve this affect and avoid any possible gaps because all of it will be forced out due to the mounting pressure anyways. This is with extremely thick pastes such as Thermalright TFX.
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
I'm on older gpu's so I can't say anything about 20 or 30 series gpu's at all beside they were just to freaking expensive to bother with
Never spread paste on a gpu only on cpu
I'd use a large X and + on a gpu, not all that tall of paste either then call it a day.
5,471 (3.65/day)
Colorado, U.S.A.
freeagent
10,368 (4.29/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
My TR coolers clamp down tight as fook, bubbles are not something I concern myself with, just an even application with the correct amount.. nothing more nothing less :D
64K
6,773 (1.67/day)
Processor i7 7700k
So this expert has never heard of a bad TIM application that had to be re-pasted because of temps being high? I have seen plenty of these on tech sites. If the TIM is spread all over the IHS in a haphazard way and the result is not good then what else could it be besides air pockets?
I'm not sure what tight as fook is but I'm not comfortable with putting unusual pressure on the CPU pins when there's no need to.
freeagent
10,368 (4.29/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Its fine, the pressure isn't on the pins anyways. And trust me, its not unusual, its well engineered.
22,161 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
I would say plain ol' air from "not enough in x place" than "air pockets," which implies a trapped bubble.
2,668 (0.80/day)
Yeah I think cover is the key part between both surfaces. I usually cover both surfaces lightly and like a small dab in the center for a bit extra that can spread and settle once pressure is applied and during heat cycles over time. You don't want excess to the point it's oozing out the sides, but you don't want too little with too poor coverage either.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Exactly what I do, never had a problem with this method. Mount hardware, thats another story.
AM5 users will need to be a bit more careful with TIM and its parking garage.
