Thrustmaster Announces New Heart Controller With HallEffect AccuRate Technology
GFreeman
1,876 (2.40/day)
Thrustmaster is thrilled to announce the integration of its cutting-edge H.E.A.R.T. (HallEffect AccuRate Technology) technology in its range of ESWAP gamepads through the new ESWAP SH5 HALL STICK MODULE mini-sticks, as well as in a new gamepad, HEART CONTROLLER. Backed by 15 years of proven expertise in magnetic sensors for flight simulation, H.E.A.R.T. delivers exceptional, lasting precision, allowing mini-stick movements to be tracked to within 0.01 degree, while eliminating drift issues.
ESWAP modular gamepads have set the standard for performance-oriented gamers and competitive gaming professionals. Now, with the integration of Hall effect technology in ESWAP modular gamepads, gamers can enjoy this innovation without having to purchase a new gamepad, by simply replacing the modules. In addition, Thrustmaster is expanding its lineup with HEART CONTROLLER, a new gamepad that natively incorporates H.E.A.R.T. technology. Gamers will benefit from the brand's expertise in a more affordable model, while enjoying the renowned precision and responsiveness of ESWAP gamepads.
ANTI-DRIFT MAGNETIC REVOLUTION
Endorsed by gamers, H.E.A.R.T. (HallEffect AccuRate Technology) represents 15 years of Thrustmaster expertise in Hall effect technology applied to flight simulation joysticks. H.E.A.R.T. provides you with unparalleled precision over time, while eliminating drift through ultra-precise magnetic sensors that measure your stick movements. Providing you with optimal control, even after hundreds of hours of gameplay.
PERFORMANCE THAT DEFIES TIME
Drift is a common problem, where the cursor moves even when the joystick is not being pressed. The potentiometers of traditional gamepads wear out over time, lose precision and cause drift. H.E.A.R.T. technology measures the position of the stick without any mechanical contact or friction, thereby eliminating this problem. The gamepad maintains its original precision over a long period of time, thus ensuring a consistent and reliable gaming experience, and giving you the best possible control even after hundreds of hours of play.
With H.E.A.R.T., your sticks capture every movement with surgical precision, within 0.01 degree. You enjoy optimal responsiveness that faithfully reproduces each of your actions. It's a real game changer, especially for games where precision is essential. You have total control and unerring precision in your movements, even in the most intense situations.
ESWAP - THE ERA OF HALL EFFECT MODULARITY
With ESWAP gamepads' Hot-Swap technology, you can easily switch between symmetrical and asymmetrical configurations to match your gaming style. Now, you can enhance your experience with the new ESWAP SH5 Hall Effect Module, featuring H.E.A.R.T. technology, without needing to buy a new gamepad. These modules, compatible with the entire ESWAP range, significantly improve your gameplay by offering greater and more durable stick precision. Say goodbye to drift issues - with H.E.A.R.T., your modules and gamepads will last longer.
HEART CONTROLLER: PULSE BEYOND TIME
Thrustmaster's new HEART CONTROLLER gamepad brings together all the know-how of the brand in the design of high-performance gamepads, which accounts for the success of the ESWAP models. This gamepad is more affordable and, while it lacks features like trigger locks and modularity, it still delivers exceptional performance. It features H.E.A.R.T. technology for enhanced precision and durability, and its highly responsive mechanical buttons are 64% faster than traditional membrane-based buttons (laboratory tests).
You can also customize the central LED color with 6 options and fine-tune all internal settings via the ThrustmapperX software. Adjust stick sensitivity, trigger travel, and remap the two back buttons to adapt the controller to your preferences and gaming style.
For Xbox users, the THRUSTMAPPERX app is conveniently accessible directly from the console menu.
Access to Xbox Game Pass Ultimate service
HEART CONTROLLER includes 1 month of access to the Xbox Game Pass Ultimate service. Play hundreds of other console games for free as soon as you get your ESWAP!
Valid for new Xbox Game Pass Ultimate members only. Credit card required. Unless you cancel, you will be charged the then-current regular membership rate when the promotional period ends. Terms, exclusions, and streaming limits apply. Xbox Cloud Gaming (Beta): available for select devices and regions. Upon redemption of the code, existing Live Gold and/or Game Pass for console/PC membership(s) will upgrade to Ultimate at a conversion ratio. Game catalog varies over time, region, and by device. See xbox.com/gamepass. Limit: 1 code per person/account.
Availability and Price
HEART CONTROLLER is available at a suggested retail price of £89.99/€99.99/$99.99. Available commercially on November 12, 2024.
375 (0.37/day)
France
Processor AMD Ryzen 7 5700X3D
Motherboard MSI MPG B550I GAMING EDGE WIFI Mini ITX
Cooling Noctua NH-U12S Chromax Black
Memory Corsair Vengeance RGB Pro SL 32 GB (2 x 16 GB) 3600MHz CL18
Video Card(s) AMD RX 6750XT Reference Design
Storage 2.5 TB 2.5" SSD / 3 TB HDD
Display(s) ASUS 27" 165HZ VG27WQ / Vertical 16/10 iiyama 25" 75Hz ProLite XUB2595WSU-B1
Case be quiet! Dark Base 700 RGB
Audio Device(s) PSB Alpha P3 / LOXJIE A30 Amp
Power Supply EVGA SuperNOVA 650 GA
Mouse Cooler master MM720
Keyboard Roccat horde
VR HMD Oculus Rift S (please Valve, release a new headset)
Announcing this just after I've buy an hall effect 8 bit do controller because every capacitive Thrustmaster stick was defective after some month of rocket league. :ohwell:
17,900 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
@GFreeman is it just the sticks that are hall effect, or do the triggers also have hall effect?
I use 8bitdo too, affordable, reliable, and good quality!
375 (0.37/day)
France
Reliability is what I want but rocket league is hard on sticks. I will see how well it goes but I want it to last more than 6 month-1 year before being unusable.
17,900 (4.66/day)
Case NZXT H710
I really don't see hall effect 8bitdo dying on you, even after a year of usage.
time will tell!
Ruru
S.T.A.R.S.
13,768 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Looks like there's almost XFX logos on the thumbsticks.
