- Oct 7, 2008
- 1,888 (0.31/day)
System Name | The Beast |
Processor | Intel Core i3-2100 @ 3.1GHz |
Motherboard | Asus P8P67 LE |
Cooling | Stock |
Memory | 4GB Corsair Vengeance DDR3 @ 1600MHz |
Video Card(s) | 1GB Sapphire Radeon HD4650 Ultimate Edition |
Storage | 60GB Corsair Force LE, 1TB Samsung SpinPoint F1, 500GB Seagate |
Display(s) | 22" Samsung T220HD & 19" Acer X193W |
Case | Corsair Obsidian 750D |
Power Supply | Corsair HX650W |
Software | Windows 7 Ultimate x64 |
Whenever I open uTorrent and download, it seems to hog the entire connection, Xbox Live is useless as is streaming music and video and browsing the net on the laptop I'm using is really bad, it's slow and every second page seems to fail to load.
20Mb downloads at approx 2,500kbps and my torrents are downloading at between 150-250kbps, so shouldn't that leave room for other devices just like on my PC? i.e if downloading torrents at 200kbps, other downloads on Firefox can use the rest of the speed.
Even with bandwidth allocation set to low, it doesn't help nor does downloading just a couple of things, it seems I can't do both, I'd like to be able to play over Xbox Live or just stream a video from my PC.
I'd prefer if I was even just able to download at like 25kbps or something if I can use my 360 properly, just as long as some progress get's done on my downloads. It's not even just playing and streaming on my Xbox, just logging in and browsing through the marketplace doesn't work properly. Browsing the net on my own PC is fine though a littler slower than usual, but anything else trying to use the net won't work or when it does it doesn't work properly.
Everything is wireless, the router is open and it's N1 so it has pretty good range meaning my cheap neighbours are probably using it, though there's no guarantee but I can pick up a router from 3 houses down the street, so there's probably 10 houses that can pickup our 20Mb connection, another person has an open connection which is 3Mb and I doubt others have as fast a connection as us.
Could it be the upload speed? My upload is a measly 1.5Mb and is approx 175kbps and my torrent upload is capped at 145kbps which doesn't leave much left.
I'm moving house on the 21st and might be able to put the modem and router in my room, would it help if I connected my 360 via ethernet?
