[US] TP-Link SR20 - AC1900 router & Zigbee/Zwave Hub only $50.00
431 (0.08/day)
System Name All the Cores ... (VMs)
Processor Ryzen9 5900x
Motherboard Gigabyte X570 Aorus Master (Bios F36c)
Cooling Noctua NH-D15S
Memory TridentZ neo 4x 16gb 3600Mhz C16 (F4-3600C16D-32GTZNC)
Video Card(s) RTX 3070 Ti
Storage 2x Sn750 2TB
Display(s) OPTIX MPG341CQR & LG 32UD60-B
Case CASELABS M8
Power Supply EVGA SuperNOVA g5 750w
Mouse Corsair m65 Pro
Keyboard Corsair K70
Software Windows 10pro/64
Benchmark Scores N/A .. yet updating soon
TP-Link SR20 - AC1900 router & Zigbee/Zwave Hub on clearance $50.00 .
Heads up .. The reviews are no grate ... however .. I bought one 2 days ago to just test it out and see.
Its not bad .. first off Update the firmware .. that fixes most issues.
But their are some issues .... if you already have a hub set up it will cause some probs. The first time installing it is a witch ... have to use A phone app, however once you are done with the set up you can just use the gateway IP .. btw on this router is was 192.168.0.1 not the normal 192.168.1.1
other issues .. you need to make account with TPlink for app and to set up the router .. that also means you have to have internt just to use it as a router the first time.
I want to use it as a Switch / AP / USB network .... had to first set it as its own router with internet .. change the default gateway to 192.168.1.2 and then turn of the DHCP Server. cant change is gateway if it dont have the internet on the WAN port to start .. weird
