TPU Ryzen BIOS Digest Issue #10
22,200 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4200(Running 1:1:1 w/FCLK)
Case Thermaltake Core X31
In this issue of the Ryzen BIOS update digest, we have the latest updates. Our BIOS update digest lets you keep track of crucial BIOS updates that improve stability of your AMD Ryzen machine. As per usual, only updated BIOSes from the last digest are listed. Changes are listed after each BIOS, sans beta BIOSes which do not always include change logs. You can find it all below.
In this release, we have several new betas, mostly all consisting of fresh AGESA 1.0.0.6a code.
MSI:
ASRock:
  • Fatal1ty X370 Professional Gaming V3.00
    Update AGESA to 1.0.0.6a
  • X370 Taichi V3.00
  • Fatal1ty X370 Gaming V3.00
  • X370 Killer SLI/ac V3.00
BIOSTAR:
372 (0.06/day)
Where the beer is good
System Name Karl Arsch v. u. z. Abgewischt
Processor i5 3770K @5GHz delided
Motherboard ASRock Z77 Professional
Cooling Arctic Liquid Freezer 240
Memory 4x 4GB 1866 MHz DDR3
Video Card(s) GTX 970
Storage Samsung 830 - 512GB; 2x 2TB WD Blue
Display(s) Samsung T240 1920x1200
Case Bitfenix Shinobie XL
Power Supply Cougar G600
Mouse Logitech G500
Keyboard CMStorm Ultimate QuickFire (CherryMX Brown)
Software Win7 Pro 64bit
What does 1.0.0.6 a bring to the table compared to 1.0.0.6?
3,668 (0.67/day)
Portugal
By common versioning etiquette, my guess is improvements, no new features.
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Anyone else sick of all the "GAMING" crap? I spend a lot of time on games, but I don't need all my stuff marketed as GAMING this and that.
Durvelle27
6,823 (1.46/day)
Memphis, TN
System Name Black Prometheus
Processor Ryzen 7 3700X
Cooling Thermalright PA120 SE
Display(s) ACER AOPEN 34" 3440x1440 144Hz
Power Supply EVGA 600W
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Need to get this downloaded
18,460 (2.47/day)
a for alpha? Asus only used that in beta UEFI releases at least.
Asus has really sucked at getting out UEFI updates for their AM4 boards, which is really annoying. I thought I made the right move at first, but seeing the list of updates from other manufacturers, I'm quite frustrated with Asus...
22,200 (3.43/day)
Olympia, WA
System Name Pioneer
My knowledge is limited as far as AGESA 1.0.0.6a. I would assume it is only a minor revision.
22,200 (3.43/day)
Olympia, WA
System Name Pioneer
But is it a beta or a stable release?
of AGESA? No idea. As I said I know nearly nothing about this release and AMD hasn't exactly been forthcoming with details. I'd just go with the "if it's a stable release bios, it's probably stable code" mantra for now.
HTC
4,694 (0.75/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
In my board's version (Taichi), the move to AGESA 1.0.0.6a also increased the BIOS version from 2.4 to 3.0. This tells me that it has some "improvements" or it would have gone to ... say ... version 2.5, or something along those lines. What are the changes? Dunno :(
1,494 (0.22/day)
Orange County, CA
System Name Battle Station
Processor AMD Ryzen 9800x3d
Motherboard Gigabyte X870E Aorus Pro Ice
Cooling Lian Li Galahad 240
Memory Corsair Dominator DDR5-7200
Video Card(s) 1 x Gigabyte RTX 4090
Storage Samsung 990 pro 2TB
Display(s) Samsung G9 Odyssey
Case Hyte Y60
Audio Device(s) Meze Empyrean 2 + Ferrum Erco Gen 2 + JBL SLR 308 speakers and SLR 310 subwoofer
Power Supply Corsair SF1000W
Mouse Lamzu Thorn
Keyboard The rabbit hole of custom mechanical keyboards
Software Window 11 x64
I have the same board and the only noticeable improvement is I can increase my ram speed to 3066 for a 2x8 GB set rated at 3200. Still can't get my 1700x to 4.0 but that could be limited by my chip.
259 (0.05/day)
Poznan, Poland
On my Biostar X370GTN new BIOS is total fail. This is why:
- none of my memory kits work at XMP settings anymore while on older BIOS all could work at 3200 stable ( higher frequency kits were limited to 3200 but could run at XMP timings etc )
- Ballistix 3466 memory is the only one which can boot at 3333 but isn't stable ( on Intel this kit can make 4133+ ), TridentZ 3200 C14 or any other kit can't even boot at 3200 using auto or manual settings while on older BIOS, all could make 3200 CL14 stable
- P States option was removed and there is no option to set any lower voltage than stock ( auto ), it means that my CPU will run at higher than required voltage and will generate additional heat ( I have small ITX build ), this board sets voltage = VID+ as it has no LLC so when I set 3.7GHz on 1700X then voltage is between 1.3 and 1.4V while all it needs is 1.2-1.25V.
- Bclk option is barely working, board randomly freezes above ~101MHz and the only way to make it work again is to clear CMOS - there is jumper for that ... and in small ITX case it's a pain to do that
All that for 2 months waiting.
HTC
4,694 (0.75/day)
Portugal
Ouch :(
I haven't changed to the Taichi 3.00 BIOS since pretty much all BIOS options (version 2.40) are @ default values, for now, including memory speeds. The reason for this is because i'll leave the BIOS tinkering for after i've grasped a bit more of working with Linux.
