HellasVagabond
- Jan 19, 2007
- 3,376 (0.50/day)
- Athens , GREECE
System Name | SECONDARY RIG / PRIMARY RIG / THIRD RIG |
Processor | i920@3.6GHz / i920@4GHz / AMD Phenom II 955 |
Motherboard | Gigabyte EX58-UD4P / Gigabyte EX58-UD7 / ASRock 890GX3 |
Cooling | CoolIT Domino ALC / Thermalright Silver Arrow / Thermalright VenomousX |
Memory | 12GB DDR3 @ 1800MHZ / 6GB DDR3 @ 2250MHZ / 4GB DDR3 @ 1600MHZ |
Video Card(s) | XFX ATI RADEON 5970 / GAINWARD NVIDIA GTX 580 / 2xGEFORCE GTX295 |
Storage | 1550GB / 6TB SAS - SSD / 160GB SSD |
Display(s) | NEC 26WUXi2 / NEC 3090WQXi / SONY 55A2000 (1080P 55inch) |
Case | COOLER MASTER HAF 932 / COOLER MASTER ATCS 840 / ANTEC DARKFLEET DF85 |
Audio Device(s) | Soundblaster X-Fi Xtreme Music / SoundBlaster X-Fi Fatal1ty Pro / Realtek Onboard |
Power Supply | CWT 1200W / Enermax Revolution 85+ 1250W / Ikonik Vulcan 1200W |
Software | Windows 7 x64 / Windows 7 x64 / Windows 7 x64 |
Transcend Information, Inc. (Transcend), a global leader in flash memory products, is proud to launch the 8GB 40-pin Vertical High Speed IFM (IDE Flash Module), the highest capacity among this type of product worldwide. This IFM (Vertical Type) is compact in size, measuring just 61.0mm x 26.9mm x 7.1mm, and has strong data retention. The 40-pin IDE Flash Memory Module is ideal to be used in harsher, more demanding industrial environments such as industrial PCs, embedded systems, medical instruments, factory automation systems, network infrastructures and other industrial equipment.
Compared to a hard disk drive, an IFM offers better shockproof effect, longer data durability, and higher data transfer rate. With built-in ECC (Error Correction Code) functionality and lower power consumption, Transcend's IFM ensures highly reliable data transfer for high-end computing applications.
Transcend uses only original SLC (Single-Level-Cell) NAND Flash chips in its IFMs, which provide higher writing speeds. Transcend's 8GB 40-pin IDE Flash Modules (Vertical Type) are the perfect choice for those who need performance and reliability. Transcend offers capacities ranging from 32MB to 8GB for different industrial needs.
Product Features
Fully compatible with devices and Operating Systems that support the IDE standard
Built-in ECC functionality ensures highly reliable data transfer
Lower power consumption
Product Features
