Trying to clone boot drive in Macrium Reflect, having an issue
1,152 (0.23/day)
Motherboard ASRock X670E Lightning PG
Cooling Thermalright Phantom Spirit 120SE CPU cooler, 3x 140mm, 1x 120mm case fan
Memory 32GB G.SKILL Flare X5 DDR5 6000 (PC5 48000) F5-6000J3038F16GX2-FX5
Video Card(s) Zotac RTX 4070 Super Trinity Black
Storage 2TB Sandisk SSD, 2TB P31 SK Hynix, 4TB WD SN850X, WD Black 6TB, WD Red Plus 12TB
Case Fractal Design Definse S
Power Supply Seasonic Focus 750
Mouse Logitech Pro
Keyboard Corsair Strafe Cherry MX Silent w/red LED
VR HMD Meta Quest 2
Trying to make a clone of my boot drive (currently in use). Trying to clone a 2TB Sandisk SSD to a 6 TB Toshiba HDD. Using Macrium Reflect Free, which used to work fine. Just want to do a quick clone in the event something goes wrong with a motherboard swap.
I formatted the HDD with a Quick Format in Win 10.
Edit:
I believe I found the problem. When I plugged in the HDD, in my motherboard BIOS it was in the boot list in the first priority slot. I disabled that, booted back into Windows. Now I can clone properly.
This thread can be closed.
What Disk Management shows:
What I see in Macrium Reflect:
Source and destination disks:
Summary of what I assume it will do, Next is greyed out, so I click Finish.
After clicking Finish:
I am greeted with this message, which I never saw before:
Not too sure what this means. Not interested in creating a Restore or running in some Restore environment. Just want a cloned drive as the end result that can directly boot into Windows should I need it.
Any suggestions on how to just clone the SSD to the HDD?
3,943 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
First, if its an OS drive, dont do that whilst its booted, use the boot media.
I also think backing up to an image, then restoring the image is better than direct cloning. As you then have a backup that can be restored to infinity with no source drive required.
Also finally make sure the alignment is suitable for the new drive, it probably is though if the source drive is an SSD.
