Tserver problem when I try do the RX580 XFX memory test in ubuntu 20, can not install amdgpu driver in Ubuntu 14
JennyLi
2 (0.00/day)
Hi, when I try do the RX580 XFX memory test, I get a soft tserver,
1. when I use it in ubuntu 20, it comes error:
Can't locate suite_bp.pl in @INC (@INC contains: ./../../external/non-amd/release/perl/lib ./perllib /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.32.1 /usr/local/share/perl/5.32.1 /usr/lib/x86_64-linux-gnu/perl5/5.32 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl-base /usr/lib/x86_64-linux-gnu/perl/5.32 /usr/share/perl/5.32 /usr/local/lib/site_perl) at tswrapper.pl line 78.
Perl aborted
2. When I use in ubuntu 14, I can not install amdgpu driver, thus the system can not reconize this gpu.
Anybody can help?
Thanks
Hello
First tell us if you can put the card in a windows environment.
If yes, let windows boot, then start GPU-z and make a picture from the main screen.
On the other hand, how you ended up to this error?
What was the previous symptoms ?
