Two GPU temperature values?
Dosch
1 (0.00/day)
why does GPU-z display two values for my GPU temperature (XFX GTX 275 XXX)?
The first one is always about 8 degrees higher than the second one.
Riva Tuner only displays the lower one, Real Temp and Furmark only display the higher one.
So which one is correct? :confused:
Kind regards,
Dosch
theorw
770 (0.12/day)
Athens GREECE
Processor C2D 8400@ 4,05GHz(currently)1,36v
Motherboard DFI LP x48 DK T2RS
Cooling XIGMATEK 1283 w/ bolt-thru kit/SCYTHE Mushashi x2
Memory Crucial BALLISTIX 6400 @900MHz 2,00v
Video Card(s) HD 5770 1040/1400 unlocked/musashi
Storage SG 120GB+WD 160GB
Display(s) 24" FLATRON W2442PA Full HD
Case COOLERMASTER HAF 932
Power Supply Thermaltake PUREPOWER RX 600
Software Vista ultimate SP1
Benchmark Scores VANTAGE:11700 3DMARKO06:18600 FURMARK:9K
It must be a temp further in the core of the core!!!
All modern cards have temp sensor like this!
My 4850 has 3 sensors in the core i think...They all have different temps!
Noth8ing to worry about really!
Have a look at my 3 bottom gpu z readings to understand!
3 (0.00/day)
Ankara, Türkiye
Processor Intel Core i7-5820K
Motherboard Gigabyte X99 Gaming G1 Wifi
Cooling NOCTUA NH-D14
Memory G.SKILL RipjawsX 4x4 3000 cl15
Video Card(s) MSI GTX 980 Ti Lightning
Storage Corsair Neutron GTX 240 & Sandisk X300s 256 GB
Display(s) BenQ XL2420T 120hz + 3D Vision 2 & Samsung 55JU6570
Case Corsair Air 540
Audio Device(s) SB X-Fi Titanium HD + Sennheiser PC 360 + Logitech G35
Power Supply EVGA G2 850W
Mouse Razer Mamba T.E & Corsair M60
Keyboard Logitech G510
Software Windows 10 64 bit
RivaTuner: 2.24
GeForce: 190.38 WHQL Vista 32
GPU-Z: 0.3.4
Everest Ultimate: 5.00.1650
809 (0.12/day)
Tampa FL
Processor AMD Ryzen 3800x
Motherboard Asus TUF Gaming X-570-Plus (WiFi)
Cooling Corsair Hydro Series H110i
Memory 32 GB Corsair Dominator RGB DDR4 3200 Mhz @3600
Video Card(s) Asus AREZ RX Vega 64 Strix OC 8GB
Storage Samsung 970 EVO Plus 1 TB
Display(s) Asus PB258Q 25" 2560x1440
Case Cooler Master Master Case 5 Pro
Power Supply Corsair RMx 1000
Software Windows 10 Pro 64
Maybe it's because the 275 has 2 GPU's and it's showing the temp of each. The reason for the temperature discrepancy is probably due to relative load on each GPU.
wolf
Better Than Native
8,676 (1.32/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Thats the GTX295 that has 2 GPU's
I too have seen this on more than one card :confused:
W1zzard
Administrator
28,613 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
one temperature is read via the driver, the second temperature is read via the sensor chip directly. both are "gpu temperature", not environment/memory or something similar.
pick one and stick to it.
W
wolf2009
so which one is correct considering there is 8C difference
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
are there not 3 sensors on the video card?
one inside the GPU core.
One inside a Memory chip.
and one on the PCB.
that would explain why you get different tempreture readings.
so 48.0 would be the Gpu Core temp, 40.0 is the memory temp and 41 is the temp of your pcb...
this seems to be how my GTX260 works. if i stress the GPU, the core temp shoots right up but the pcb temp rise's slowly, if you touch the outside metal case around the video card you can feel it slowly warm up.
scandalous
1 (0.00/day)
I'm seeing 2 gpu temperatures as well. I wonder which is the correct one. I hope it's the one that's 8c lower ofcourse.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
If you want to be "safe" just look at the higher temperature reading.
reilan
2 (0.00/day)
After installing nforce driver 190.62, one of the gpu temperature reading had gone missing from my gtx 260.
