Undervolt issues.
babaco86
3 (0.01/day)
Hi guys. I recently undervolted my pc and I always try to make it go further in offset voltages. I tried -120mv in cpu core and cpu cache and I can run gta 5 perfectly with heavy use (20-30 mins of gameplay). But in game if ı change the power plan to power saving plan then I get a BSOD. Should I keep -120mv or go to my before voltage settings?
I am asking about is this means its unstable?
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
Please start by filling out these details.
Then we can talk specifics
48 (0.08/day)
System Name Shirakami
Processor 7800X3D / 2000 & 2000 IF & UCLK
Motherboard Gigabyte B650i AORUS Ultra
Cooling Corsair iCUE H100i ELITE CAPELLIX w/ ultra slim 2x120mm fans
Memory 2x24GB Hynix M-Die @ 8000 - 38-48-48-40 - 40k tREFI & tuned subtimings
Video Card(s) 6900 XT Reference / -120 mV @ 2.4 GHz
Storage 1 & 2 TB NVMe - 1 TB SATA SSD
Display(s) LG 34GN850 (3440x1440) 160 Hz overclock
Case Lian Li Q58
VR HMD Reverb G2 V2
Software Fedora Linux 41 operating system (daily)
Hi, please fill out the system specifications details or give us a general idea of what you're using.
But to answer your question, the reason you are crashing when power saving is activated is because of the built in V/F curve.
When you set a negative -120 mV undervolt, you are setting it for all voltage/frequency curves.
If your system idles at 0.800 @ 800 MHz , it will now idle at 0.680 @ 800 MHz , which may not be enough to retain idle stability. There are portions of the CPU outside of the cores that have a minimum necessitated voltage, like the cache. The core voltage is shared with the cache (assuming you're on Intel). The cores might be stable at something like 0.680 , but the cache needs that higher voltage to function properly.
You can either set the performance plan to High Performance and leave it there - which has a tendency of locking your voltage and frequency at the highest setting.
Or you can set a static fixed voltage to assure it never goes above or below your target voltage (example: a target voltage of 1.10v - don't actually use this voltage. I don't know what hardware you're running. It is an example.)
The difference in idle power draw between a static fixed voltage and an adaptive offset is minimal (on modern CPU's), so long as your C-states are active.
I also recommend at the very least using Cinebench R15 and R23 to stress test. Ideally you would download OCCT (it's free) and run the built-in CPU stress test for 30 minutes, assuming all you do is game on said machine.
44,274 (6.80/day)
Your undervolting is causing instability when adjusting the powerplan, don't do it
7,493 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
True, and not all cpu and gpu's are happy with uv and it sometimes can take a long time to validate properly.
My own RTX 4070 ain't happy with the average RTX 4070 uv settings to get it down to like 150-160W from 195W so I choose to leave it and did a mem boost instead and it keeps peaking at 195W not going over.
