Unexpected low scores
334 (0.05/day)
UK
System Name Moose 5800X3D
Processor AMD Ryzen 7 5800X3D 3.4Ghz 4.5Ghz Boost 96MB L3 Cache
Motherboard Asus Prime X570-P
Cooling Custom Liquid Cooling covering CPU and GPU including liquid backplate for graphics memory cooling
Memory G.Skill Trident Z RGB 32GB (2 x 16GB) DDR4 DRAM 3600MHz CL18
Video Card(s) PNY GeForce RTX 3090 XLR8 Gaming 24GB
Storage WD Black SN770 2 TB PCIe 4.0 NVMe M.2 + Samsung 970 EVO 1TB PCIe NVMe M.2 + 2x WD Caviar Black 750GB
Display(s) AOC 34" CU34G2/BK Ultra Wide @ 3440x1440
Case Thermaltake Level 20 HT
Audio Device(s) Creative Sound Blaster Z SE
Power Supply Corsair TX850M 850W Semi Modular
Mouse Razer Viper Ultimate
Keyboard Rii K61c
As you can see in my system specs; I have a fairly fast PC, I find that modern games run well at high settings. However I ran a couple of benchmarks; pcmark 10 and performancetest, and I am getting low scores around 2/3 what I would expect comparing with similar PCs, mainly focusing on the GPU tests. Obviously the scores aren't horrendous but here is the pcmark: https://www.3dmark.com/pcm10/62651364 I think a RTX3090 should be doing better than this! Any ideas?
FreedomEclipse
~Technological Technocrat~
24,780 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Your CPU is a good one but its still bottlenecking your 3090. That explains the low score you are seeing.
334 (0.05/day)
UK
Keyboard Rii K61c
You think so even on the graphics tests? I should look at CPU utilisation while they run!
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Probably better to use passmark not pcmark
334 (0.05/day)
UK
Keyboard Rii K61c
Problem has now been solved; nvidia control panel was limiting frames to ~266fps so this affected the easier tests more and barely affected others. The above comments about the CPU are also correct but they didn't have as great an effect as first noticed (33%).
FreedomEclipse
24,780 (3.76/day)
Slap a 3300X (or 3600X) in that thing and you'll be good to go.
167 (0.10/day)
USA
Processor 5800x3D
Motherboard x570 Extreme 4
Cooling Deepcool AK620 Digital
Memory 2x16 Steel Viper 3600 Mhz
Video Card(s) 4070 SUPER FE
Storage 500 GB WD SN750 / 870 Evo 500 GB / Kingston 480 GB SSD
Display(s) Alienware 34 aw3418dw / ROG Swift pg27q
Case Corsair 3000D
Power Supply Seasonic V3 1000w
Mouse Model O
Keyboard GMMK Pro w/ SP Magic Girls
Software WIndows 10 Pro
2/3 would be correct as the 2700 will bottleneck it around 20-30%. depending on the tasks.
