Unformat NTFS help!!
2,555 (0.38/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Help.
How do I unformat a "quick format" of an NTFS volume?
Blame it on the beer!! :toast:
-bump- Need help guys. Anyone know of a free utility to recover a format???
I know Acronis Disk Director Suite will do it, but it's not free. I'll see if I can scrape something up.
EDIT:Forgot to ask, is it your Windows partition, or just a data partition?
I found this: http://www.pcinspector.de/file_recovery/UK/welcome.htm
Scanned with Kaspersky and it came up clean. Installed it and ran it, but couldn't test it, as I have no deleted partitions. Worth a try I suppose. That is if your comp still boots. If not it's back to the drawing board. lol
I tried Acronis and I couldn't find anything anywhere to recover a format. I'm scanning with GetDataBack for NTFS right now. It doesn't look like the format itself can be recovered. I miss the old unformat dos utility. Best I can do is try file recovery on it. So far that hasn't worked well using O&O Format recovery. It has trouble writing the recovered files to another drive. 1000s of write errors and a bsod will result. Windows in general has trouble copying alot of files in one shot. Drag and drop a folder with literally 1,000,000 files in it and xp will choke. On another note, has anyone ever noticed issues with Western Digital drives on an overclocked rig?
It was a single drive 250gb data partition that was quickformated ntfs. I had backup folders on it of mp3s, pictures, etc and due to xp's above mentioned file copy bug I have to copy folders one at a time. I got all but one. I thought I had them all because the destination drive showed 25 folders which is what the source drive had but one of the 25 was the damn system restore folder and that screwed up my count. A folder was missed. :banghead:
get active@ partition recovery it can normaly recover from those situations :)
