- Nov 30, 2007
- 227 (0.04/day)
- Croatia
System Name | Cabal |
Processor | intel i9 9900k @ 5.0ghz 1.33v - cache @ 4.7ghz |
Motherboard | Asrock z370 fatal1ty gaming k6 |
Cooling | Corsair H115i with 2x Corsair LL140mm rgb fans |
Memory | Corsair Dominator Platinum 32GB(4x8kit) ddr4 4000mhz@4100mhz |
Video Card(s) | Msi rtx 5070ti Gaming OC 16gb |
Storage | samsung evo 860 500gbx2, sandisk 3d ultra 500gbx2, kingston hyperX ssd 480gb, Seagate Barracuda3TB |
Display(s) | Asus ROG Swift pg278q G-Sync |
Case | Corsair 760t Graphite Series with 3x Corsair LL140mm fans |
Audio Device(s) | Sound Blaster X ae-5 |
Power Supply | Corsair RM850i |
Mouse | Roccat Tyon |
Keyboard | Corsair RGB Strafe mechanical keyboard |
Software | win10pro 64bit |
So a couple of weeks ago i noticed when i shut down pc the light on my external usb hdd keeps blinking like there is still some data trasfer going on
So i disconnected the usb cable(while pc being off) and connectect back again.
But since then every time i boot the system, upon entering windows now it keeps getting disabled.
Control panel shows the above message with code 43, hdd lights blink like crazy
If i uninstall the device nothing happens and it stays disabled, restart wont help ONLY if i disconnect/reconnect while in windows the hard drive appears again and is usable.
I tryed to cold boot the hard drive on a laptop and is booting fine everything works so i think it's not the drive itself but probably win registry part for this usb hdd is corrupted.
i found the device in windows registry but it says access denied
i tryed full format and changing letters/names of the drive but the issue persist
any help?
any help?
