- May 24, 2013
- 35 (0.01/day)
Processor | Ryzen 7600X |
Motherboard | Asus TUF Gaming B650M-Plus Wifi |
Cooling | Arctic Liquid Freezer II 280 |
Memory | 32GB GSkill Trident |
Video Card(s) | EVGA RTX 3080 FTW3 Ultra |
Storage | WD Black SN850x 2TB |
Display(s) | Gigabyte M27Q |
Case | Thermaltake Core V21 |
Power Supply | Corsair AX850 - 80 Plus Gold |
Mouse | Razer DeathAdder Chroma |
Keyboard | Steelseries Apex |
I finally planning an upgrade to my old 3570K but need some advice since it's been 10 years since I did a platform upgrade.
The PC will mostly be used to gaming since I have a corporate laptop for work. Also I don't want any high-end/premium stuff since experience tells me I will end up using 5% of that premium stuff.
So, I'm thinking of the following new parts:
CPU: Ryzen 7600X or 7600 - Any pros/cons on any one of them? Why should I chose one over the other? They're almost the same price...
MB: Must be mATX. First I was thinking of ASUS b650m Prime but some friends told me that Prime boards are usually low quality. Should I go ASUS TUF? Does the price increase justify it? Any other option?
RAM: My only question here is if should I go 16GB or 32GB. The specs I'll chose based on the QVL of the chosen MB.
NVME: I'll probably pick the cheapest 1TB or 2TB from a reliable vendor (anything will be better than what I have now).
Parts that I'll keep:
Case: Thermaltake Core V21
GPU: EVGA RTX3080
PSU: Corsair AX850 - 80 Plus Gold - I believe that it should be enough but comments on this pls.
Cooler: Arctic Liquid Freezer II 120 - It's compatible with Zen 4 but is it enough to cool the 7600(X)?
Storage: 3 WD HDDs 2TB/3TB.
Hope I'm not forgetting anything.
Thoughts?
GPU: EVGA RTX3080
Thoughts?
