- Oct 19, 2007
- 1,162 (0.18/day)
- Lancs,UK
System Name | Mr_average ( hoping 1 day to upgrade to Mr_above_average ) |
Processor | AMD Ryzen 7 7700x |
Motherboard | Asrock B650 Steel Legend Wi-fi |
Cooling | Arctic Freezer III 240mm AIO RGB - White | 4 Lian Li ST120mm case fans - White |
Memory | 32gb Corsair Vengeance RGB 2x16gb 6000mhz DDR5 - White |
Video Card(s) | Asus Dual GeForce RTX 4070 12GB OC - White |
Storage | 1tb WD Black Nvme | 2tb WD Black Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme |
Display(s) | D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz |
Case | Lian Li Lancool 2 Mesh RGB - White |
Audio Device(s) | Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset |
Power Supply | Corsair TX650M Semi Modular 80+ Gold |
Mouse | Razer Basilisk V3 |
Keyboard | Razer Huntsman V2 |
Software | Windows 11 Pro |
hi all, current specs listed.
thinking of upgrading to the following
but the box itself only mentions AM4 and lower... so will it, wont it? if not, what air cooler would you recommend for the 7700x ?
The other thing is PSU, I currently have a Corsair TX650M PSU which is approx 4 years old, would you carry it over or would you replace it ? if replace would a 750w be enough ?
any suggestions, ideas would be most helpful
thanks.
MSI B650 GAMING PLUS WIFI Motherboard, ATX - Supports AMD Ryzen 9000 / 8000 / 7000 Series Processors, AM5 - 14+2 Duet Rail VRM, DDR5 Memory Boost 6400+MHz/OC, 2 x PCIe 4.0 x16, 2 x M.2 Gen4, Wi-Fi 6EMSI B650 GAMING PLUS WIFI Motherboard, ATX - Supports AMD Ryzen 9000 / 8000 / 7000 Series
Corsair Vengeance RGB White 32GB 6000MHz DDR5 Memory Kit
AMD Ryzen 7 7700X Processor (integrated Radeon Graphics, 8 cores/16 threads, 105W DTP, AM5 Socket, 40MB cache, up to 5.4 GHz max boost, no cooler)
thanks.
