Upgrade CPU or replace motherboard?
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
Currently I'm running an i7-6700 on a Gigabyte B250M motherboard.
I have been using my PC to transcode Linux ISOs from h264 to h265 but while the GPU does the heavy lifting for encoding the CPU does the decoding in Handbrake and my CPU is pegged at 100%.
I also do web development and some gaming, but I'm running a GTX1050 so the CPU isn't a bottleneck here although I do want to buy a new GPU when things go back to normal although it might take a while.
I'm trying to decide whether it's going to make any difference upgrading to an i7-7700k or I should just wait a few months and buy a new motherboard and buy a new 12th gen CPU. the 7700k is cheaper for now but I think replacing the entire platform is more reasonable long-term given that the 7700k isn't that much better than my 6700.
13,943 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
So this is a different system than shown in your System Specs? I note that says an i5.
How much RAM do you have? Hard drive or SSD?
I see no reason to upgrade the CPU today if you might replace the motherboard next year. This is because a new motherboard often requires a different CPU (and RAM). If you buy a new CPU today, it may limit your options for new board next year, unless you don't care about wasting money today.
1,861 (0.53/day)
North Dakota
System Name Office
Processor Core i7 10700K
Motherboard Gigabyte Z590 Aourus Ultra
Video Card(s) Intel ARC A750
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
... replacing the entire platform is more reasonable long-term given that the 7700k isn't that much better than my 6700.
It seems as though you've answered your own question, particularly given that you're running on a multiplier-locked board.
1,237 (0.28/day)
System Name Sierra
Thank you for the reply. I haven't updated any of those specs for a long time.
I have 32GB DDR4, three SSDs (1x NVMe and 2x SATA), and I updated original post with correction I'm running a GTX1050 not FirePro W7000.
It does seem that just waiting and going for a whole new platform makes sense given the price of a used 7700K is like $300! Although I could sell my 6700 for about $150 it seems.
13,943 (2.04/day)
Nebraska, USA
Mouse Logitech M190
That assumes someone will buy it - and not hold out for a whole new system too.
315 (0.21/day)
System Name Back in Black
Processor Ryzen 7 5700X
Motherboard MSI B550 Tomahawk Max WIFI
Cooling ID-Cooling SE-224-XT Black
Memory ADATA XPG 16GB (2x8) 3200mhz C16
Video Card(s) XFX RX 6700 XT Speedster Merc 319 _larry Edition
Storage Solidigm P41 Plus 1TB / Crucial MX500 500GB
Display(s) Samsung 32" TV 1080p
Case Montech Air X Black
Power Supply Thermaltake Toughpower GF1 750W Gold
Mouse Redragon M711 Cobra
Keyboard Corsair K55
I agree. Only if the 6700 was showing signs of going down the silicon graveyard, then it would make sense to get another CPU while preparing for the new build.
1,237 (0.28/day)
System Name Sierra
Thanks all, I will not waste my time or money on an i7-7700K, I appreciate the input. Will just wait and save for an entirely new motherboard and CPU.
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Exactly. As from 6nd gen to 10th gen, they're identical in performance in clock to clock (though later gens have more cores and higher stock/boost clocks), so a 7700K would be a waste of money. Have you any plans for the upgrade?
11,097 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
upgrade motherboard. 12600k and z690 or b550 and 5800x.
578 (0.32/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
you can also try out some of the chinese repurposed cpus, because B250 can work with 8th and 9th gen with modified bios. That would be the most cost-effective solution to increase performance and get 6 or 8 cores. something like this https://www.aliexpress.com/item/100...sceneId":"3339","sku_id":"12000024751596165"}
Alder lake is still a ...lake, intel isnt doing much progress so it doesnt make much sense to shell out for 12th gen as its still slower than amd and is more power-hungry.
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
you can also try out some of the chinese repurposed cpus, because B250 can work with 8th and 9th gen with modified bios. That would be the most cost-effective solution to increase performance and get 6 or 8 cores. something like this https://www.aliexpress.com/item/1005003228035285.html?spm=a2g0o.detail.0.0.1a0270c8Jnrqsc&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=57dfea5d-44ee-442d-95c8-5fb41c232001&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:57dfea5d-44ee-442d-95c8-5fb41c232001,tpp_buckets:668#2846#8111#1996&&pdp_ext_f={"sceneId":"3339","sku_id":"12000024751596165"}
It has a different architecture, not anymore that Skylake shit. Also Rocket Lake moved away from that (tho still 14nm+++++++++++)
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Moar cores.
Go AMD for your next system
578 (0.32/day)
yea, but that is like cedar mill vs northwood, the core 2 duo is yet to be released ))
performance per w (the real deal) for 12900K is much worse than 5950, and is in fact still comparable to the older 14nm i9's
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Those new Intels are great, but it feels unfair that people say that now AMD sucks, AMD had 5000 series already when 11th gen dropped.
I'm not a fanboy though I like more AMD, I'm just waiting for Zen4 to see how the tables turn. :)
I admit that there's one brand where I'm a fanboy and that's Sound Blaster soundcards :laugh:
2,450 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
+1 on a new mobo and cpu
3,192 (2.27/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
There is no such thing as ROI on a consumer PC. They are expenses not investments.
Buying shares of NVDA, AMD, or NXPI can result in ROI.
11,097 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
It's going to be a leapfrog again -- which is what we want... whenever any company gets too far ahead it just means insane prices for the good stuff
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
One thing which I've never done is hop on the new RAM train - it costs hella lot compared to the old gen..
3,192 (2.27/day)
You buy anything, its an investment.
Nah.
The common sense definition of an investment is putting your money into something that you expect to turn a profit.
Examples of things that aren't an investment: refrigerator, bath towels, car, smartphone, electric toothbrush, t-shirt, 2 liter bottle of soda pop, Blu-ray player, and PC.
Examples of things that might be considered investments: shares of GE, TM, AAPL, KO, SNY, DELL. Yeah, I know I missed a few. If I cared enough, I could fire up a search engine and figure out the appropriate stock symbols.
Investment: mint-quality Leica M6
Not an investment: whatever consumer-grade dSLR that Canon puts out next
Investment: 80-year old Bugatti
Not an investment: 2022 Toyota Camry fresh off of some manufacturing line
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
I kinda think that some of you my opinions are meh - I'm more into price/performance myself. My 3600 / 1080 Ti budget pack still kicks a punch.
3,192 (2.27/day)
You are absolutely right valuing performance-per-dollar (or whatever currency is standard in your country).
The biggest issue right now is that the silicon shortage threw those out of whack a year ago. 4-year-old $65 GPUs are now going for $200+.
Street price and true value are very, Very, VERY far apart right now for certain items.
13,943 (2.04/day)
Nebraska, USA
Mouse Logitech M190
LOL But it wasn't unfair when people claimed Intel sucks? You are right, by the way, it is unfair. But it was unfair when the shoe was on the other foot too.
That's the problem with fanboys - regardless the banner they stand behind, the fanboys are convinced their favorite is the one and only option for every product that company makes. And worse, they refuse to accept the competing brand is a viable option.
At no point since AMD became a viable processor maker has either company had the best processor in every weight class. Same with GPUs. Same with motherboard makers, PSU makers, cell phone makers, browser makers, anti-malware makers.
If a company makes just one product, and that product sucks across all areas of comparison, including customer support, then maybe it is fair to bash the company itself. But when a company makes dozens or 100s of products that stretch across multiple categories and multiple quality tears, and the company stands behind their products - including the lemons, then what is not fair is people saying the entire brand sucks.
There's a reason Chevy, Ford, RAM, Nissan, Toyota all claim their trucks are #1. It is because they are. One is #1 in towing, another in fuel efficiency, another in cooking popcorn, etc.
The browser wars illustrates it very well. Each can claim to be #1 because this one is faster, that one supports the most add-ons, and the other is best at blocking spyware. But not one is best in every category.
I am not aware of any processor that is best in every area of comparison.
What is unfair is people asking, "Which is better, AMD or Intel?" And worse, what is unfair is responders answering claiming one brand, or the other is better. To be fair, it should always be a specific model from company A compared to a specific model from company B.
Just because Company A's flagship device is scores better in some comparison than Company B's flagship device, that in no way means Company B sucks.
Things can be expenses and investments too. A plumber may "invest" in a van but that surely is an "expense" too.
I think a key word cvaldes included is "consumer".
I agree 100%. We need Company A always looking over their shoulder to see what Company B is up to. And we need Company B always nipping at the heels of Company A, always trying to get ahead. That is what drives competition. And competition is good for us consumers.
For me, price matters, but it is no where near top priority. It has to meet my needs. It has to be reliable. It has to perform well. And then it has to be within my budget. And almost always last, it has to look nice.
Often overlooked when pricing a CPU is the big picture. The CPU is just one component. When you factor in the cost of the motherboard, RAM, PSU, case, drive, graphics card, keyboard, mouse, monitor(s), speakers, OS and other software, the price difference between two CPUs becomes less significant. Yes, it can still be a budget buster for some, but not everyone.
LOL - This illustrates the point. For one, performance can be defined and measured in several ways - and no doubts, marketing weenies will exploit whichever ways makes their product look like the best performer. Even "per watt" can be subjective and open to interpretation.
