[URGENT]Lost C drive after checking disk checkup, no boot
477 (0.12/day)
System Name Rtxoned
Processor Intel i5 8600k
Motherboard Msi Z370 Sli Plus
Cooling Cooler Master Ml240r
Memory Corsair vengeance 8x2 DDR4 2400mhx
Video Card(s) Zotac Rtx 2080 Amp
Storage 250gb SSD, 500Gb SATA, 250Gb SATA
Display(s) Alienware 25” 240hz
Case Nzxt H700i
Power Supply Thermaltake toughpower 1000w 80+ Gold
Mouse Logitech 403
Keyboard Hyperx alloy fps mechanical keyboard Cherymx Blue
Hi, windows 10 latest build, not booting,
After try to many things like fix mbr and blabla, i figured that these cmds not working because c drive is not actually showing(i saw when i was trying to find recovery image from startup)
Is there any option to access drive? Or else? I have important data on it.
May be drive letter problem, because I found windows partition as partition1 and is other than C
What was wrong with the MBR? Did you save a backup of it?
If the 'partition1' is the same one as your previous C drive, you may just need to set it to be bootable.
if doesnt boot at all :
press f8 while turn on pc to enter safe mode then install aomei partition assistant or
install os on another disk drive to access the lost drive
http://www.majorgeeks.com/mg/getmirror/aomei_partition_assistant,1.html
Can i take backup too?
I found the partition, it seems like theresno pther option than format,
Before problem i made all partition into one and shrunk And theb rename partition labels, after then i checked for error, windows said it needs to repair, and next boot i got problem, its unable to boot, getting automatic repair at first, reset not working. Tried to fix boot but gpt this
BFSVC: Failed to set element application device
I'm still not sure exactly what happened, but it looks to me like in the process of trying to fix your problem you have accidentally corrupted your hard drive (badly too). BFSVC seems to be a Microsoft program designed to repair boot problems and it not only can't fix them it appears that it can't run properly itself! If that's true then you won't be able to enter Windows' Safe Mode either.
It sounds like you have a way with which you can access the disk. If I were you I would backup/clone the partition and start looking at data recovery options. I'm sorry, but I think it's a file and filesystem problem now and I can't help you with that nor would I recommend trying by yourself.
Ok update.
I had to recreate drives, deleted all drives, fresh installed windows. All fine now.
I would have tried a repair install before i obliterated my os...
