- Jan 4, 2013
- 1,208 (0.27/day)
- Denmark
System Name | R9 5950x/Skylake 6400 |
Processor | R9 5950x/i5 6400 |
Motherboard | Gigabyte Aorus Master X570/Asus Z170 Pro Gaming |
Cooling | Arctic Liquid Freezer II 360/Stock |
Memory | 4x8GB Patriot PVS416G4440 CL14/G.S Ripjaws 32 GB F4-3200C16D-32GV |
Video Card(s) | 7900XTX/6900XT |
Storage | RIP Seagate 530 4TB (died after 7 months), WD SN850 2TB, Aorus 2TB, Corsair MP600 1TB / 960 Evo 1TB |
Display(s) | 3x LG 27gl850 1440p |
Case | Custom builds |
Audio Device(s) | - |
Power Supply | Silverstone 1000watt modular Gold/1000Watt Antec |
Software | Win11pro/win10pro / Win10 Home / win7 / wista 64 bit and XPpro |
I recently bought a USB-C cable to Display Port and noticed a strange delay on my reference 6900XT haveing to disconnect and reconnect the cable after a cold reboot when power from the wall had been turned off
I am using this cable
www.av-cables.dk
In the USB - C slot driving my 3 monitor Eyefinity Setup
Any one else with 6900 XT cards seeing the same lack of detection after a cold reboot?
If I wait like 10 minutes after turning power on at the wall, it seems to fix the problem.
I bought the cable to see if using 3x Displayport would allow Eyefinit and HDR - it does not :-(
Btw powering the monitors off in windows dosent detect the USB-C connected monitor and didnt find a nother easy way to detect the 3 monitor except for pulling the cable out and in again
Delock USB-C til Displayport kabel - 8K/60Hz - Sort - 1 m
Dette DP 8K-certificerede USB-C til DisplayPort-kabel fra Delock muliggør forbindelse mellem forskellige enheder med USB-C og DisplayPort-stik. USB-C til…
