Tactus
- Feb 2, 2021
- 4 (0.00/day)
Hi folks. I’m experiencing some sort of interference through my speakers. It seems to be quite a common issue, but I just can’t get rid of mine, it’s most likely a motherboard issue. Here’s a video of what I’m experiencing:
drive.google.com
I’ll post my build at the bottom of this post. I use this mainly for audio production, which is my job. I use USB audio interfaces (at the moment an Arturia Audiofuse and Soundcraft Ui24R). Here are things I’ve done to try and combat it:
- Using the motherboard out of the case
- Taking all PCIE cards out
- Unplugging all case connections from the motherboard
- Trying different power outlets with different combinations (I have just moved flat and still have the same issue)
- Trying different cables (USB and speaker - balanced/unbalanced)
- Attaching a ferrite clip onto the USB cable
- Power conditioners
- Unplugging all USB connections and using the motherboards’ line out into a mixer
I’ve managed to get rid of the noise when I use a Hifime High-Speed USB Isolator, but it’s very unreliable and recently the second one I’ve had finished like the first one: the USB interface doesn’t get recognised when plugged in through it anymore.
The noise only comes out of my speakers. Recorded audio in through the interface and listening on headphones plugged into the audio interface don’t have the noise.
Even with my speakers off I can hear the noise coming straight from the motherboard only with the audio interface plugged in, and disappears when it’s unplugged. This issue only happens with my Aorus Pro Z390 machine and doesn’t with my Macbook plugged into the exact same setup.
Please help.….
Build:
Hackintosh with Mojave installed
CPU: i9-9900K
Motherboard: Z390 Aorus Pro
Cooling: Scythe Ninja 5
RAM: Corsair Vengeance LPX 32GB (2x 16 GB) 3600MHz CMK32GX4M2D3600C18
Hard Drive: ADATA XPG SX8200 1TB
GPU: Asus GeForce GT 710 2GB GDDR5
Power supply: be quiet! Pure Power 11 CM 600W
Case: X-Case 4000 Big Open 4u
Inlet fans: 2x 120mm Noctua NF-S12A PWM
Outlet fans: 2x 60mm Noctua NF-A6x25 PWM
Wireless/Bluetooth: fenvi T919 for macOS PC PCI BCM94360CD
Keyboard: Logitech K760
Mouse: Apple Magic Trackpad 2
USB_Interference_Noise.mov
Please help.….
Build:
CPU: i9-9900K
