USB port in back of monitor causing graphics lag
Easy Rhino
Linux Advocate
15,686 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
Okay is this a thing? I plugged in a USB Type B cable into the back of my monitor and attached it to my PC. I then plugged my keyboard (only) in the back of the monitor. All games lag now. I unplug the cable and everything is butter. Is this normal behavior?
13,955 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Definitely, it is not normal behavior. I assume if you plug the keyboard into the PC where you had the monitor USB connected, all still works fine, right?
Did it (the monitor's USB port) used to work fine?
I don't know but since most motherboards have designated USB ports for the keyboard and mouse, I always use them.
Easy Rhino
Linux Advocate
15,686 (2.33/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
Hrm, it seems to be inconsistent depending on what port it gets plugged into. This is the first time i am using the hub in the back of the monitor.
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Something it pulling to much power and most likely sharing power with the monitor. High power draw monitor most likely lags.
13,955 (2.04/day)
Nebraska, USA
Mouse Logitech M190
In another scenario I might agree with that but the monitor's USB hub should be getting power through the monitor's power supply, which would be isolated from the computer. And keyboards - even backlit keyboard don't draw much power.
@ Easy Rhino - have you tried a different keyboard?
Low quality post by Zareek
968 (0.44/day)
The New England region of the United States
System Name Gaming Rig
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Software Windows 11 Pro x64
Benchmark Scores Nope
14,557 (3.79/day)
Sunshine Coast Australia
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Very odd indeed.
The USB port on the Monitor should be a straight forward pass through and shouldn't affect games or the Monitors performance.
The only possibility I can imagine is interference with your internet somehow causing the lag. Cables overlapping etc.
738 (0.14/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Cooling Montech D24
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) XFX 7900 GRE
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Montech King 95 pro
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
I would say it sounds like latency on the monitors USB hub. It might be looking like graphics lag because it's reacting slower, but I would suspect it's keyboard lag.
It could be that USB hub is a cheap design for things like charging and data transfer where the input can be laggy because you are not expecting immediate effect.
Best solution is a decent powered USB hub velcroed to the back of the monitor.
Or a single cable extender just for the Keys and use the monitor USB for lower polling devices.
I've seen similar effects with high-end Joysticks. They like a nice high polling USB connection like a mouse but on some motherboards and USB hubs you can generate input lag, The effect is a stick that has a stepped input feeling and it'll show in the configuration screens. Generally, I've seen it where a 3rd party controller or a cheap hub is used.
6,396 (0.87/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Try with a different USB cable from monitor <-> PC, the current one could simply be faulty.
Check if there's a specific driver for the monitor and if so, install it.
Check if there's a firmware update for the monitor, if so install it.
It could also be a hardware incompatibility between keyboard and monitor. These things aren't supposed to happen, but they do.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
This is basically what I was going to say. I think we need a better idea of what "lag" means. Is it framerate drops or input lag?
18,467 (2.47/day)
Just out of curiosity, are you by chance using 2.4GHz Wi-Fi to connect to the internet and it's a USB 3.0 hub? If so, you could get interference from the USB 3.0 part on the Wi-Fi signal, but that's about the only thing I can think of that would cause this.
44,283 (6.80/day)
Older monitors were just pass throughs but it may share off hdmi.
Id stop using the ports and tape em off, have you tried the devices on your tower to verify it isnt the drive?
847 (0.34/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Could be just that its just not getting enough bandwidth honestly dont know
14,557 (3.79/day)
Memory 32 GB DDR4
Mouse Lenovo
From memory early Dell monitors had a few USB ports but only certain ones were powered.
6,396 (0.87/day)
Ikenai borderline!
Mouse Logitech G604
Haha, I completely forgot about that one. I still can't believe that NONE of the USB-IF members caught that issue during the design and testing phase.
19,381 (3.46/day)
Interesting this is a surprise. I don't recall what monitor I owned, but, I did the same thing...used the monitor as my USB hub with whatever connected it and had noticeable input lag. So, I didn't use it anymore assuming that was normal. I mean, it has to go through another device in the chain which I simply imagined enough input lag to notice.
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
It really lagged up my computer when I used the USB hub on my Dell S3220DGF monitor. Programs would stutter, things would be slow to load, a lot of latency increase overall. It was very noticeable just browsing the web. Started when I connected the monitor's USB, and it stopped when I disconnected the USB. I have never connected it since.
636 (0.12/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16@CL14 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage 2x4TB WD HGST 7K6 7200RPM 256MB
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
Yes, it is weird, especially this part: "USB Type B", are you sure it is type B? Or did you mean type A?
On a bit more serious note: did you upgrade monitor's firmware or tried, if possible, a downgrade?
44,283 (6.80/day)
Cheap controller with weak signal integrity.
18,467 (2.47/day)
I've used the hub on at least two of not three monitors without any issues whatsoever, so it should work fine...
Nothing weird, type B is the correct port for the input to a monitor from a PC. It would seem you need to go and read up on the USB standard.
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
are we talking bout your lg 34 monitor ?
so it has:
USB-Hub Out2x USB-A 3.0
USB-Hub In1x USB-B 3.0
LG 34GK950F-B
quote:
After LG released a new firmware for this screen in early 2019 we wanted to take another look at it. We had confirmation from LG that the update was designed to improve a couple of things. Firstly it extended the supported Variable Refresh Rate (VRR) range from 55 - 144Hz to 48 - 144Hz, which gives a little bit of a boost. Secondly, and potentially more interesting was the news that it was designed to reduce the lag.
Updated v2 Firmware Tests February 2019
We were very pleased to see that the new firmware helped reduce all of the lag on this screen. We now had a signal processing lag of only ~0.2ms,
1,015 (0.18/day)
Processor Intel Core i5 8400
Cooling Silverstone AR05
Display(s) Dell U2415
Case Silverstone RVZ02B
Keyboard Ducky One Red Switch
Software Windows 10 Pro 1909
Shouldn't happen. I connect a usb type-A to type-B from MB to my Dell monitor, and from the monitor I have my keyboard and mouse plugged in, even with a usb drive plugged in from time to time. No lag. Worked fine for both windows and ubuntu.
636 (0.12/day)
To be honest first time i hear about type B as display input. I thought type C is the first use of usb for displays. The only use for type B i usually seen was for printers and similar devices, mini/micro type B for cameras, phones and other small devices. Now i'm curious what particular monitor model Easy Rhino owns, would like to look into specification to read more about it. Over 20 years in IT and i still learn new things about something what seems to be one of basic things like display input and output and usb standard. It is like with these motherboards having display port input somewhere in middle on their surface between cpu and gpu.
18,467 (2.47/day)
It's not a display input, it's a USB hub built into the monitor that's causing the issue. I think you've misunderstood the OP's issue.
You're correct in that USB-C is the only USB connector that have official display signal support, although there have been some hack jobs using USB for all sorts of things, including PCIe signalling.
The stupid thing with USB-C is that if you want both the display signal and USB through the cable simultaneously, you end up with USB 2.0 data speeds...
The DP input on some ASRock boards is because they have some matching graphics cards, so you can run an internal cable from the DP out on the graphics card to the DP in on the motherboard to the Thunderbolt out on the rear of the board, all without any mess around the back of the PC.
636 (0.12/day)
No, you mislead me with mentioning possibility of type B as display input. In general type B is rarely used in displays, most of the time it is just regular type A. Again, actually it is first time i hear about type B on a monitor, i googled now and i see mention of such monitors using type B on their hubs. I'm aware most of the time usb on displays are just hubs and in this case i also assumed it is a hub port and was still wondering if it would be type B as i've never before seen type B connection on a monitor.
