- Feb 18, 2011
- 1,446 (0.28/day)
- Romania
Processor | Ryzen 5700x |
Motherboard | MSI B350 Gaming Pro Carbon |
Cooling | be quiet dark rock pro 3 |
Memory | GSKill Aegis 32GB (4x8GB) DDR4 3200MHz CL16 |
Video Card(s) | PowerColor Radeon RX 7800 XT Hellhound 16GB GDDR6 256-bit |
Storage | Seagate Barracuda SATA-II 1TB , HyperX Savage 240GB SATA 3 |
Display(s) | Benq EX2780Q |
Case | Be Quiet! Dark Base Pro 900 |
Audio Device(s) | Sound BlasterX G6 |
Power Supply | Seasonic prime TX-650 |
Mouse | Marvo Scorpion G981 |
Keyboard | Razer Blackwidow Elite - Yellow Switch |
Software | Windows 10 Pro |
Here we go guys
Usb Stick not working.
So it went on write protected. Did what these people over here are saying http://superuser.com/questions/338059/recovering-a-partially-formatted-usb-thumb-drive
Nothing good happened . Than i got a live G Parted cd and i managed to format it first, ntfs then fat32 as it is now. But windows does not recognize it. Because i'm a noob, i reinstalled windows. You know windows reinstall fixes everything. Almost.
Did a Ubuntu image boot on another usb stick and tried to boot Ubuntu to see if i can format the broken stick in there. Failed. The option that says try ubuntu without install does not work. And i did not want to install Ubuntu....cuz then i figured it might mess my windows. I don't know.
Anyways i installed EaseUS Partition Master . That program does the job. Creates a ntfs partition on the disk, but windows not recognize it.
Basically i can't use the stick anymore. Some people ,on some forum said that the stick might be physically damaged. If that is the case,i will put it int he garbage.
But i figured i might ask you guys for help first. After all where i come from these things are kinda expensive.
P.S.: The model is a Lexar 16GB Product of China : LJDV10-16G-000-111AD
