usb webmail notifier not working.
696 (0.16/day)
India
System Name To be ALL IN ONE MACHINE. but not yet
Processor i7 3770k
Motherboard Asus P8Z&&-V Deluxe
Cooling Thermalright Silver Arrow
Memory Gskill Ripjaws 1600Mhz 8GB *4 = 32GB
Storage Samsung pro 840 256GB, Segate 3TB and 1TB
Display(s) LG 23" Full HD LED
Case Antec LanBoy Air
Power Supply Cooler Master M2 Silent Pro 850 Watts
Software Windows 7 ulimate 64bit
Hi guys,
I bought this usb webmail notifier, which is not working in windows 7
http://www.xoxide.com/usb-webmail-notifier.html
after installation when I clcik on s/w to open it shows some drop down list to select some netcard but nothing appears on it.
Please guide, I have seen some guys made it working, is there any way to make it work on win7.
The product has zero support. You might want to try setting up Outlook.. or whatever mail client Windows 7 uses first. Also, for the software try using compatibility mode for Windows XP.
** Here's the installation manual: http://files.dreamcheeky.com.s3.amazonaws.com/manuals/WebMailNotifier.pdf Looks pretty straightforward and Windows 7 IS supported.
* Install software
* Connect USB
* Follow the rest of the manual. It does work with webmail (not just Outlook, Live, etc.)
Pretty interesting device! Are you installing the software from a CD-ROM or downloaded .exe? The software on the CD could be outdated. See if there's a new version on the web. Right click the .exe and run as administrator. I've had some programs the behaved oddly because I neglected to do so.
According to the website, it supposedly work with web-based emails and email clients such as outlook. If I had more USB ports, I'd definitely get one!
Hi Guys,
Could you please share the download link for latest software?
Thanks.
* Install software
* Connect USB
Thanks.
But the light is not blinking.....................
wHAT SHOULD i DO?
Thread necro....
