- Mar 31, 2007
- 1,895 (0.29/day)
- ontario canada
System Name | home brew |
Processor | Intel Corei7 3770K OC @ 4.5Ghz |
Motherboard | ASUS P8Z77-V |
Cooling | Corsair H100 |
Memory | 16GB DDR3 1600 GSKILL |
Video Card(s) | Powercolor Radeon 7970, MSI Radeon 7970 |
Storage | Mushkin Chronos Deluxe 240gb. 2 TB Hdd. |
Display(s) | 3x24inch Dell Ultra IPS |
Case | CM storm trooper |
Power Supply | Antec Quattro OC ed. 1200w |
Software | Windows 7 Business x64 |
Benchmark Scores | vantage: P43089 |
I'm trying to do a red hat Advanced server 4 update 7 install using a kick start file on the network. The server with the kickstart file and dvd contents is on the same subnet as the server receiving the install. We have done it before in the past just fine using:
linux nofb text ks=http://serverip/path at the boot/install screen. After that the ip address info is entered manually and the kickstart does its thing. When doing this with update 7, the install acts like a regular install. When i check the http access logs on the other server, it shows no access from the server receiving the install.
I have tried adding an ip address to the install command. Such as:
linux nofb text ks=http://serverip/path ksdevice=eth0 ip=IPADDR netmask=255.255.255.0 gateway=GATEWAY IP
The results are the same. Redhat docs for AS 4 say a dhcp server must exist, but this has been done before. Any ideas?
