Use wifi adsl router as AP connected to another wifi router
52 (0.01/day)
Portugal
System Name infected's machine
Processor w3520 @ 4.4ghz
Motherboard p6t dlx v2 0901
Cooling apogee xt, gtx-lite, mcp355, 4x nb mf s3hs, dd res. bay
Memory 6gb gskill tridents @ 1680mhz
Video Card(s) 2x asus eah5870 vt @ 990/1260 1.3v
Storage 2x WD3200AAKS RAID 0 + Samsung F1 1TB
Display(s) Hp w2207h
Case Antec 1200 (7x120mm+1x200mm)
Audio Device(s) HD 7.1 onboard + 2x100W RMS
Power Supply Nox Urano 600W SLI
Software Windows 7 X64
Hi. I have cable connection in which the cable modem is connected to a wired 4 ports router (dlink di-604). In an ethernet port in that wired router i have a wireless adsl modem/router (dlink dva-g3170i) with dhcp deactivated and the LAN ip between the same range of my wired router. until here everything is fine, i have wireless internet and local network through the wireless adsl modem/router. now the problem... i have a second dva-g3170i that i would like to use as an AP to have longer signal..
can someone indicate or explain how to do that?
Thanks.
Router with Wireless access is different (reduced) feature set compared to a dedicated AP with Bridge, or Repeater functions. Sometimes routers can be hacked for extra features. Otherwise you need a dedicated AP.
See DD-WRT or http://www.openwrt.org/ for possible solution.
