Using a Plasma as a monitor
Duekay
258 (0.04/day)
Brisbane AU
System Name Workstation : Server/HTPC
Processor Core i7 920 @ 4.2GHz : Core i3 2120
Motherboard Gigabyte GA-EX58-UD5 : Gigabyte GA-Z68MA-D2H-B3
Cooling Cooler Master V8 : Stock
Memory Corsair DDR3 12GB @ 1600Mhz : Corsair DDR3 8GB @ 1600Mhz
Video Card(s) GTX 560 Ti & GT 430 : Onboard
Storage OCZ Max I/O 2x128 SSD Raid0 + Corsair 3x120GB SSD Raid0 : Corsair 2x60GB SSD Raid0
Display(s) Dual samsung 24" & 1 Acer 22" : Acer 22 & Samsung 46" TV
Case Antec P182 Performance One : Antec 4U rackmount
Audio Device(s) Mackie Onyx 400F 10x10 : Maudio Fast Track Pro
Power Supply Corsair HX-620 : Corsair HX-650
Software Windows 7 64bit, Cubase 5 : Windows 7 64bit
I have a Small Question can you Using a Plasma as a monitor, if you can what are the advantages and disadvantages of this.
Say my max resolution on my GPU is 2048 x 1536 or so and i wanted to get a 42" plasma, what would the quality be like and could i get things to a similar scale as using a 22" LCD with a resolution of 1680 x 1050 or would it be just scale everything up and have larger pixelation?
Any Ideas :confused:
plasma screens are heavier than LCD by around 15% (if i remember right)
also difference in quality and so on would really depend on the plasma your buying and the LCD your comparing it to.
can you please post full specs?
Ok say a Panasonic TH-42PX70A 42" Plasma HDTV and a Acer X223W 22" Widescreen LCD Monitor
i thought 1080P was 1680 x 1050 (but unsure)... in that case it would just be a much bigger version of your 22"... i have a plasma TV that can do 720 P and i was actually wondering how it would work as a monitor, as well...
Keep burn-in in mind....
My boss did with a 1366x768 Plasma, wasn't bad. I never got to try any games on it though :)
I don't know how it'll turn out with a 1024x768 screen with wide-screen aspect (the TH-42PX70A).
True that... burn-in and the loads more power it uses... nothing like having the oblivion health bar permanently tattooed on the bottom of your plasma.
