Using bluetooth headphones with my computer..
panchoman
Sold my stars!
9,595 (1.46/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
Hey guys,
i'm fed up with using wired headphones and am planning on buying a good set of bluetooth headphones for my iphone and what not.. but here is my question, if i buy the asus bluetooth dongle, can i get sound on the bluetooth headphones? And would it be through the audigy se sound card? etc.etc.
when you connect the bluetooth headset to the PC the audio will mute for a moment, then be routed to the headset, leaving your soundcard doing nothing - I do it on my PC sometimes.
You can go into an app an change it's default audio device though so music will continue to you play over your speakers while you have an audio chat via the headset - the PC will set the headset as the default audio device soon as you pair it, so you will need to either change it after you pair, or set the apps you want to play sounds via the speakers to use the card.
When you unpair, the card will be returned as the default.
Hey guys,
Quality bluetooth headphones, well let me tell you, they simply don't exist. You sacrifice sound quality ALOT. Not to mention battery, and remember they only work EXTREMELY close (30ft) to the computer. I actually have to recommend INFRARED, cause if you don't smoke, the sound quality is much better than bluetooth.
I've heard actually the opposite when it comes to bluetooth vs infrared... the main problem with infrared is that it requires a large reciever and any sort of object(such as pillars) will cause the signal to be dropped.. i know some people complain about bluetooth quality, but since bluetooth is already built into my iphone and laptops, i'd be much easier to use bluetooth..
