Using car coolant to cool CPU ?!
911 (0.36/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600, OC: 4.0 GHz @1.3 V
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
So today a guy asked me if it's ok to use car coolent in his watercooled system instead of using regular water so he can achieve better temps , i was shocked when i first heard the question , and then i thought that this can actually work , what do you guys think ?
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
You won't get better temps on ambient water.
Only reason to use antifreeze in your loop is as a biocide or galvanic corrosion inhibitor, unless you plan on sub zero coolant.
419 (0.13/day)
System Name Baxter
Processor AMD Ryzen 7 5800X3D
Motherboard ASRock B550 Phantom Gaming ITX
Cooling Scythe Mugen 5 Rev. B with Noctua NF-A12x25, NF-A9
Memory 16 GB Crucial Ballistix Elite DDR4 @ 3600 MHz
Video Card(s) ASRock RX 9070 XT Steel Legend
Storage WD SN850X 4 TB PCIe 4.0 M.2 SSD
Display(s) Sony X90J 65" 4KTV @ 120 Hz VRR
Case Corsair NR200P
Audio Device(s) Samsung Q930C Atmos 7.1.4 Surround Sound system
Power Supply Corsair SF750 Platinum 750 W SFX PSU
Mouse Logitech MX Master 2S
Keyboard Logitech G613 and Microsoft Media Keyboard
VR HMD Meta Quest 3
I doubt you'll get better temps. Car coolant is probably tuned for much higher temperature differentials than a processor could reach. And I would be worried about corrosion or degradation of the loop somehow with a coolant not designed for a computer liquid cooler.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It isn't an issue, and actually was pretty common back before the fancy fluids came out.
It will definitely help with corrosion too, especially in a mixed metal loop. Car coolant systems are almost always mixed metal, so the anti-freeze has a ton of corrosion inhibitors.
2,349 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
I would say the pink variety over the green, any thoughts?
2,100 (0.47/day)
Spencerport NY
System Name Master
Makes no difference.
2,349 (0.43/day)
Keyboard Dell
14,541 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
If overclocking and or using a chiller, pink has the longer lifespan and greater temperature range.
2,100 (0.47/day)
Spencerport NY
System Name Master
If you're using a chiller and are serious about it, you use windshield washer juice. It has less viscosity cold than antifreeze does and will not slush up to -30 or so.
So you would not use Dex-Cool. That would be my first choice.
I didn't say that. I said it makes no difference what brand you use. They all do the same thing.
2,349 (0.43/day)
Keyboard Dell
That' s due to the alcohol. That can't be good long term?
2,100 (0.47/day)
Spencerport NY
System Name Master
Been using it in my chillers for a decade or more. No issues ever.
It evaporates a little, just keep it topped up.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
No Dex-Cool, I wouldn't even run that crap in my car! It eats rubber seals. Classic green is what I always use or the yellow stuff.
freeagent
10,353 (4.29/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
That's a good idea, with the winter washer fluid. Where I am, we have stuff rated for -40c, but I think its ok when its colder. My dexcool sounds like its running through a Slurpee machine when its that cold lol. Its not nice.
14,541 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Just use Vodka, it won't freeze and you can regularly drain the system with a straw :laugh:
3,984 (1.08/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
Anything that doesn't have plasticizer in it.
968 (0.44/day)
The New England region of the United States
System Name Gaming Rig
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Software Windows 11 Pro x64
Benchmark Scores Nope
Correct me if I'm wrong but doesn't straight water conduct and absorb more heat? If so, the anti-corrosive benefits of anti-freeze are a good thing but I seriously doubt he will see better cooling performance.
6,871 (1.10/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
That's why you don't use pure antifreeze. You always dilute it with water for the temperatures it is to be used in.
Outback Bronze
Super Moderator
2,195 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Razer
Keyboard Corsair
Software Win 11
Been using car coolant for 10+ years. No issues here and extremely happy with it.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Distilled water + ethylene glycol car coolant is my choice. Like 10:1 or even more. Using mixture like that for years. No problems ever.
Outback Bronze
Super Moderator
2,195 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
The car coolant I use is very similar, but I think its more 50/50 mix straight out of the bottle.
193 (0.08/day)
System Name Zen4
Processor Ryzen 9 7950x
Motherboard Asus Strix B650E-E Gaming WiFi
Cooling Some oem 240 AIO
Memory 2xKingston DDR5 2x16GB (Hynix M die)@6000 CL26-35-35-27
Video Card(s) Gainward Phantom 4090 (@2.82GHz .95V UV, 350W PL)
Storage WD Black SN850X
Display(s) LG OLED C1 48"
Case Phanteks P600S
Power Supply Corsair RM1000i
Mouse Logitech G Pro X Superlight
Keyboard Corsair K70
VR HMD HP Reverb G2
Software Win11
I bought a few PA series Thermochill radiators 12 years ago, and I also received 2 small (2 oz?) bottles of something with this description on it:
Valvoline Racing
Super Coolant
Zerex
On the back label:
Contains: Water, Ethylen Glycol, Potassium Hydroxide, 4-Hydroxybenzoic Acid, 2-Ethylhexaonic Acid, Corrosion Inhibitors, Silicone Silicate, Defoamers and Dyes
Instructions: Dilute with distilled water at a ratio of 5% coolant to 95% water
And I have used it with great success all these years, but I'm all out now and looking to buy more. I can't find this exact product in my country, but is it just plain anti freeze? Even the nickel plating on many EK blocks have survived over the years. Oh and it's red/pink :)
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
I have to mention that some car coolants now does have stupid additives to make it not sweet (in some countries like UK) so children and and animals do not drink it, when leaked etc...
I don't know how that suits with our scenario.
14,541 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Valvoline Racing
Super Coolant
Zerex
On the back label:
Sounds like it is, Valvoline is an Automotive brand.
dorsetknob
9,106 (1.24/day)
:) here is one that remembers the Wine Scandal (from Austria ) years ago.
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
I've considered actually getting some Benzotriazole (BTA). It is recommended for protecting copper.
