- May 27, 2008
- 3,629 (0.58/day)
System Name | Ultra 64 |
Processor | NEC VR4300 (MIPS R4300i) |
Motherboard | proprietary design |
Cooling | Fanless aircooled |
Memory | 4.5MB 250 MHz RDRAM |
Video Card(s) | 62.5 MHz Reality Coprocessor |
Storage | 32 - 512 Mbit ROM Cartridge |
Display(s) | 720x576 |
Case | Clear Blue Funtastic |
Audio Device(s) | 16-bit CD quality |
Power Supply | proprietary design |
Mouse | N64 mouse for use with N64DD |
Keyboard | N64 keyboard for use with N64DD |
I appear to have a problem using my E8200 with my Asus P5N32-SLi SE Deluxe. If i put it in it starts to post all dandy goes through the few different screen till it get to checking NVRAM where it will hang in deffinatly. I say that because the longest i have left it is about 20min, i dont no if it will need to take longer but surly not when all it needs to check is like a 4mb bios chip right?
Ive tried different ram, ive tried just one stick in every channel and two sticks varying channels. Cleard CMOS even bought a new battery for it but no luck. I can get into my bios and change setting etc but i cannot seem to find an option to disable the check. If i run my E2180 all is fine so i no the mobo/ram are compatable.
Any ideas on how to fix this issue guys?
cheers ste
cheers ste
