Ussing 2 different DDR3 RAM's with different speed
171 (0.04/day)
New Delhi, India
System Name Devil's Hell
Processor AMD Ryzen™ 5 2600X Processor 2nd Gen 3.6GHz
Motherboard MSI X470 GAMING PRO MAX
Cooling Corsair H60 (2018) 57.2 CFM Liquid CPU Cooler
Memory Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16
Storage Segate 2 TB, WMD 250 GB M2
Display(s) Samsung T23B350AR
Case Cooler Master MasterBox Lite 5 RGB ATX Mid Tower
Audio Device(s) Motherboard
Power Supply Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply
Mouse Logitech
Keyboard Logitech
Software Windows 10 64 Bit
Hello Team,
Is It possible to use 2 different RAM with different speed in same system.
Current Config
Core i5 4440
MSI H97M-G43 Mobo
GTX 1060
Current RAM (2 slots 4 GB each)
G.Skill RipjawsX 4GB F3-12800CL9S-4GBXL
Looking to add a new
Kingston HyperX FURY Memory DDR3 8 GB PC (HX318C10F/8)
As much I know it should be ok untill and unless using same DataRate which is supported by Mobo that is DDR3.
It should work, but BIOS will probably set all RAM to the lowest speed DIMM (1600, maybe 1333) and run in single channel because of mismatched DIMMs. That will result in worse memory performance, unless you are frequently using more than 8GB. If you ARE running low on memory, the extra 8GB will let you multi-task longer. Most RAM is so fast, you won't really notice the difference between single and dual channel operation. I would just try it, and see if it boots and recognizes all sticks.
So issue I am facing is utilizing almost all of RAM while running some application (usual development kit and performance test tools) such as some times it shows RAM utilization to almost 90% or even more...resulting into system freeze or restart.
So, as per your comment it may not be best choice but yes it will help in multitasking, and it wont do any hardware damage (which was my concern as I dont know much)
It's far from ideal, but if you need the capacity of extra RAM, yes it will help, and no, it won't damage anything.
and dont forget some ram may not work if they are different. back to compability
The board will always default to the "lowest and slowest" of mixed RAM So ideally you want to get as "close" as you can to what you have.
Hello Team,
Current Config
Core i5 4440
MSI H97M-G43 Mobo
GTX 1060
Though it "should" work... by setting the lower clock speed of the two, it really isn't something taht should be done... if only for the sake of stability.
That usually doesn't happen anymore. It will instead run in asynchronous dual-channel. Where it will use 4GB of the 8GB stuck to match the other 4GB stuck, and run that in dual-channel, then the left over 4GB will be accessed in single channel. So once you surpass the 8GB usage mark, the speed will drop to single channel speed. But it won't slow down the first 8GB like it used to in the old days.
If the OP really is running out of RAM at 8GB, adding 4GB more, even if that 4GB runs at single channel, is better than nothing.
It'll work, but it's not ideal. It's best to have a matching set. I'd spring for a fresh 16gb kit if possible if I were you.
So either I would get 2 4gb same ram stick or whole new 16 gb kit....
It seems that is what you all are asking...correct me If m wrong the RAM is nt delivered yet...I can get smw thing else...
@saknid as the others say shouldn't be a pro blem just keep in mind that your motherboard will slow the fastest DDR3 ram down to the clocks of the slowest.
Like if u pair a set of 1600mhz and 1886mhz the kit that's set to run 1866mhz will be down clocked to 1600mhz because your motherboard don't know if your 1600mhz memory can run 1866mhz.
Now I get it...thank you brother...
@saknid I am glad I can help that's what I am here for :)
I've mixed ram before, usually (most of the time) it has worked, occasionally not.
